Results 1 to 7 of 7
Thread: Ride Height
    Established Member Two Rings ZFURR27's Avatar
    Jun 27 2014
    Gillette, NJ
    Ride Height
    Yesterday a couple of friends and I spent the day installing H&R Street Performance coils on my 2011 A4. Right now I'm sitting at about 25 inches from ground to fender in the front. My wheel specs are 19x8.5 et 38 with 255/35/19 tires. I'm a little concerned about rubbing in the front. Anyone running a similar setup and have a preferred ride height? Any input that could help me prevent rubbing would be helpful.
    thanks
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    26" all around is a safe bet
    Pedal Responce first responder.
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    I have almost the same setup but with 245/35/19.
    You'll rub on hard corners because of the 255s. If you roll your fenders, you shouldn't worry too much. I'm on coils at 25 1/4in with 19x8.5 wheels and 10mm spacer in the front so my offset now is 45.
    I don't rub hardly at all.
    My current rides...
    Audi
    Jetta
    Established Member Two Rings Darktrooper79's Avatar
    Feb 20 2015
    2019 AUDI A3 Quattro
    United States
    My ground to fender is 25.5" lowered on ST coilovers. Wheel specs are 19" x 8.5", 35ET. Tires 255/35/19. no rubbing issues ever.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Running a 255/35/19 on an 8.5" rim with ET35, you should have no issues rubbing what so ever. My current AR sits on 19x8.5, ET35, H&R coils @ 25 1/4" front, 25 1/2" back. Even with 20mm spacers, I do not rub.
    Mar 20 2016
    Elmira, NY
    I'm at 26" all around and its low enough to look good, but still able to function on NY's shitty roads. The rear has rubbed a couple times on the bigger bumps (I'm on 19" rotors with 255's) so I have to play with it a little bit.
    Jun 27 2014
    Gillette, NJ
    I appreciate everyone's responses. I didn't adjust the coils at all but I did have the fenders rolled slightly and now I have so much more clearance. Im at 25 in the front and 25.25 in the rear. I tested it on some of the windy and bumpy roads around me and no rubbing anywhere. I'm going to drive it around like this for now and see how it goes. In the future I may go up to 26" but right now i have no issues
    2016 Q5 3.0T Glacier White Metallic Quattro P+ Technology Package// Sport Interior Package
    (former) 2011 A4 2.0 T Brilliant Red Quattro P -APR Carbonio Intake//AWE Quad Tip Touring Edition Exhaust//AWE Carbon Fiber Rear Valance// H&R Street Performance Coils// Hartmann HRS6-204-GS 19x8.5 ET +38// Pirelli P Zero All Season Plus 255/35/19
