As some of you may have seen on some of my other posts that I recently completed a swap in my '03 Avant from the 5 speed to an 0A3 6 speed out of an S4. Everything worked out great and the car runs and drives beautifully. The only issue I have is the shifter. I got a shifter out of an 05 A4 (B6) as I was led to believe that it would be what I needed. It does indeed fit and shift the transmission fine, aside from one aspect that is annoying. The gears are backwards from where they should be. Instead of having reverse, first, third and fifth on top, I have second, fourth and sixth. Basically it seems as if the X-axis pivot is backwards. I cannot tell if I have the wrong shifter or the wrong linkages. I can find info about the S4 shifter but not the A4 shifter, and I can find info about the A4 rods but nothing on the S4 rods. Anyone have a source for me to look over and find out what I need to locate to put my gears where they belong?
Here is my setup. It looks exactly the same as the setup in my wife's B7 with a 2.0t and 6 speed. Hers shifts opposite of mine, telling me the shifter probably pivots different.
Help? Please?
