Results 1 to 11 of 11
    Sep 28 2009
    suburb
    Anyway to get compass directions instead of NAV on screen?
    I had loaner 2016 a6 and it shows compass direction on screen in dash instead of saying NAV and the little globe symbol in my 2013. Is there a way to make it show compass directions? I miss the compass directions in my older Audi rear view mirrors.
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    I think I stumbled over it once when I discovered that the left side steering wheel thumb thingy changed stuff.
    Mar 29 2014
    Hampshire, UK
    You can enable the compass option via VCDS, as l enabled it on my 2014 A7.
    Must admit lve not enabled it (or missed it) on my S7.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Sep 28 2009
    suburb
    Quote Originally Posted by jkwelsh View Post
    Do you know the coding for the VCDS?? Thanks
    Audi SQ7
    Audi B8 S5 (gone)
    Mar 29 2014
    Hampshire, UK
    Here is a list of all the VCDS options that Im aware of....
    http://www.vwaudiforum.co.uk/forum/s...C7-VCDS-Tricks
    If I recall correctly, the compass was enabled via the hidden service menu in the MMI. (which you have to enable via VDCS in order to then access)
    https://youtu.be/36uYU2Uj6ng
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    jk, doing this enables the compass in your rearview mirror, or on the NAV screen? I too miss not having it in the rearview mirror. OP, the alternative is to have it display in the instrument cluster.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by Brooklyn View Post
    Enables on the instrument cluster.
    Sep 28 2009
    suburb
    There are 2 compass menu options. Do you know which one you changed? Thanks
    Audi SQ7
    Audi B8 S5 (gone)
    Jul 27 2013
    indianapolis/indiana
    you can get the compass on your dashboard in between the tach and speedo by using the left scroll button on the steering wheel to change the options without using vcds. It has a ton of information
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    Sep 28 2009
    suburb
    Quote Originally Posted by dab View Post
    yes i know that, but I would prefer (if possible) to just show the compass direction on the screen all the time instead of the little globe symbol and NAV next to it.
    Audi SQ7
    Audi B8 S5 (gone)
    That’s exactly what I’m trying to do change the lettering from NAV to the actual direction. Did you ever figure out how to do that, I have an OBD 11 and I’m trying to activate the Compass menu
