DO NOT use anything to spread open the gap in the control arm clamp! If the gap is spread open, the grip on the control arm ball joint will not be uniform around the ball joint shaft when the new bolt is retorqued, negatively effecting the gripping force developed by the clamp bolt on the ball joint shafts.
For clearance using a pneumatic hammer gun, cut the head off the bolt with a hack saw, then hammer the bolt out of the triple clamp in the backward direction. Use an impact tool in the hammer gun that is slightly smaller diameter than the bolt, grind to size as needed, with a ground point on the tool to fit into a conical drill point drilled into the bolt shank, to help keep the impact tool from moving away from the bolt centerline before the bolt is moved enough for the bolt hole to guide the impact tool. As already mentioned above, apply limited heat to the triple clamp around the seized bolt, to help free up the bolt. DO NOT over heat the triple clamp! 200 to 300 degrees F, is the maximum heating temp. Overheating the aluminum triple clamp will weaken and damage the triple clamp.
If when drilling the seized bolt, use a small pilot drilled hole first, then use a larger drill and conical point drill tool. The small pilot hole will be easier to drill, and will result in drilling with a larger drill bit will then be a lot easier and faster also.
