Yesterday (Saturday) I was planning to buy a new 2016 S4 (200 miles on it) with 7-spd DSG transmission from the local Audi dealer. Within seconds of starting it up, it felt like probably one cylinder was misfiring, then probably two cylinders misfiring. The out-of-balance shaking of the engine was significant. The salesman was sitting in the back seat and said he felt it too. He told me to drive it around the lot, and so I did. The shaking/misfiring did not go away, and the engine was running for a couple minutes. It was so significant that we decided to not take it on the road. The car was taken into the service dept, and after waiting 25-minutes, I was told that everything is fine now. I test drove it again and the misfire was gone, but there was an odd hesitation from stand-still or from very slow speed, and the car did not feel as strong as other B8 S4's I had driven. So we went to the Service Dept, and I asked what was wrong and what was done, and they said there was a "random misfire code" and that they cleared the codes, and that everything is fine now. They said they don't think it'll happen again. I asked why the misfiring issue had occurred. They first said that the car was sitting for months. But I said I can tell that it wasn't sitting for weeks or months because the brake rotors were very clean. Then they said that it must have been bad gas or winter gas still in it (there was half a tank of gas in it). So I asked if they emptied all the gas and put new gas in it. They said "No". They only cleared the codes. They admitted that they didn't know why the misfiring happened, and that after they cleared the codes they couldn't duplicate the problem. When I asked further about the gas, the spark plugs, and the fuel injectors, they said that until the misfiring happens again, they "are not allowed to touch" any of that.
The sales manager got involved, and he pulled the "key" records showing how often someone has taken the keys to this car, and it showed that in the prior 5-days, the keys had been taken 4-times, and that two of those times it was for customer test drives. He could not (or would not) say what the other two times were for. So clearly that car had indeed been driven multiple times over the past week. It had not been "sitting" for a long time (which doesn't seem to be a good reason for a new car to misfire anyways).
It was late in the day at that point, and I was very uncomfortable with buying a $62,000 car that had a significant problem that the dealer couldn't determine the cause of, and didn't do anything but clear the codes, so I walked away.
-What causes that misfiring issue, and what needs to be done to fix it?
-What do think about the Audi dealer's behavior?
