Results 1 to 4 of 4
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    timing chain replace
    https://jhmotorsports.com/shop/catal...te-p-1083.html
    Looking into replacing my timing chain. Found this online and am inquiring on it, but, I also hear about replacing the plastic guides with metal ones from the RS4. Will the B7 metal guides work on my B6 S4? I saw a link for the parts but need to look into it again.
    Not being the huge gearhead yet, I am probably going to have the local independent shop do this work for me.
    Insight, opinions? Thanks.
    Oct 05 2015
    Billings, MT
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    I wouldn't use the OEM adjusters , if you end up needing them. (they can still wear out)
    the kits from JHM all come with the metal backed guide IIRC, atleast mine did .
    how many miles do you have ? any cam timing related codes ?
    if you don't have any cam timing codes, I would order the JHM basic plus kit , and wait until your mechanic gets the cam adjusters off the engine. (you'll see if you need them or not.)
    Oct 05 2015
    Billings, MT
    I get a powertrain code. But the VW dealer said it is because of a motor mount solenoid. But nothing else. I get the chain rattle though. I have 158k on it bought it at 130k no knowledge of chain had been replaced yet.
