Results 1 to 40 of 55
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Real-time Supercharger Teardown
    I picked up a damaged supercharger on Craigslist from a 2015 A7 with 10k miles on it. I was planning on using it on my car, but it's a little too damaged for me to use the whole thing. Now I'm going to gut it and send out a few parts to some members on here and maybe swap the internals for mine with 111k.
    I figured I'd post some pics on here and get some help along the way.
    Here's a pic of the damage. The car was in a wreck and it looks like it bent the water inlet flange and took a chunk out of the bracket that holds the front belt cover on
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Jul 05 2014
    Houston
    Throttle body and map sensor were easy enough! Any takers??
    Jul 05 2014
    Houston
    7 bolts held in the bypass valve. Why can't I just weld this thing shut?!?
    Jul 05 2014
    Houston
    Here is a comparison of supercharger oil
    Here is new supercharger oil
    This is your supercharger oil at 10k
    Here is your supercharger oil at 110k
    I suggest changing somewhere between 10k and 110k ;)
    Jul 05 2014
    Houston
    Surprised by how much additional oil came out when I pulled the front off.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    SCARY, how did your supercharger die, it died at 110k miles?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jul 05 2014
    Houston
    Quote Originally Posted by RedS-line View Post
    Actually my supercharger is on the car and still rocking. This super charger with 10k from an A7 has some damage on the housing or plenum. So I'm tearing it down and selling/reusing what parts I can. Plus it's practice if I decided to work on my supercharger later.
    Jul 05 2014
    Houston
    Here are the scrolls coming out, I was worried I'd have to pull the gears on the front, but the whole thing just slides right out when you break the seal
    Just begging me to take the dremel to it!!
    Jul 05 2014
    Houston
    Does anyone have some pro-tips for removing the intercoolers without breaking them?
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Do us all a favor.. Send the oil from the 100k+ charger and send it for analysis.
    Would be nice to know what's going on with that
    Nice pics btw thanks for taking the time to do this
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jul 05 2014
    Houston
    Got the intercoolers removed... Do not try to pull or pry on these things to get them out. I started with the bent one first and tried pulling on the back gently. It came out but I ended up bending some fins and bending the flange on the back... On the good one I just beat the front with a rubber mallet and it just popped right out with no damage
    Dec 19 2014
    Virginia
    Quote Originally Posted by fitzydude View Post
    Rubber mallet got mine out
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    Love this thread. Thanks for doing this.
    Jul 21 2004
    South Florida
    Quote Originally Posted by jmaddr View Post
    I agree. Thanks so much.
    mike
    2018 Audi S5
    Gone-
    Jul 05 2014
    Houston
    If anyone needs any parts from this I'll post them for sale on the classifieds. Thanks!
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    I wish someone would develop a higher flowing IC coolers with less pressure drop by decreasing tube/fin count (larger). Stock IC fins/tubes look small, maybe we may see some gains there with an AMS or APR external cooler and secondary coolant pump? Any thoughts?
    Thanks for taking the time to tear apart SC, I'm in for oil results.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Veteran Member Three Rings cchoi83's Avatar
    Nov 10 2014
    Long Island, NY
    Quote Originally Posted by DGVR6 View Post
    This.
    2018 RS 3 | Nardo Gray | Crescendo Red | Dynamic Plus | Black Optic | RS Design Pkg | Tech Pkg | Dynamic Pkg
    P3 | XPEL Ultimate Full Wrap | Nanolex Si3D HD
    I swear I'm keeping this one stock.
    Eventuri CF Intake | JRZ RS PRO3 | BBS CI-R | Michelin PS4S
    Nov 01 2015
    2012 Q7
    FL
    Good job!
    2014 S4 P+
    APR STAGE II & PULLEY, APR TCU TUNE, 034 X BRACE, REAR SWAY, MOUNT INSERTS, REAR SOLID END LINKS, CR-15, ECS INTAKE, DIPSTICK, F&R SPACERS, REAR WAVE ROTORS, STAINLESS LINES, HPS 5.0 REAR PADS, STOPTECH 380MM BBK
    2012 AUDI Q7
    STOCK
    Senior Member Two Rings A.Bruno6's Avatar
    Jun 02 2015
    Ontario Canada
    This thread is great! Thanks for taking the time to do this!
    EPL Dual Pulley & TCU |3.19 PR| -- MercRacing Charge Air Cooler
    Established Member Two Rings xcnovanrunner's Avatar
    Sep 11 2013
    Uxbridge, MA
    +1
    2010 Audi S4 Prestige 6MT Sprint Blue
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Very interesting to see what makes our cars so fun taken apart! Lol. Nice thread.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    where do you get the S/C oil from? Might have to change like every 30k or something.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by chaos2984 View Post
    ECS sells it: https://www.ecstuning.com/Search/Sit...Oil/ES2099956/
    2016 S6
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    You can also buy the oil from Chevrolet..Cts v and vette use the same oil..It's only $6 a bottle,you need 2 bottles though.
    Sent from my SM-G900W8 using Tapatalk
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by s4matty View Post
    WOW @ the Audi tax on this fluid!
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    I kinda wish teardowns like this were done with a gopro attached to their head. That way, not only do we get pics, but an informational video.
    Thanks for the photo's though, this is great info!
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Jul 05 2014
    Houston
    Quote Originally Posted by amz View Post
    Haha well that would just be me half drunk and cursing for 4 hours. I'll keep it in mind when I do something like this again.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Hahaha
    2021 Audi S4, P34 Intake
    Apr 29 2013
    Ottawa
    Quote Originally Posted by jsh139 View Post
    And this, ladies & gentlemen, is where that sweet whine comes from :D
    Really? Does the sound get transmitted through the lobes and then back into the intake? I'm curious why going from stock to, for ex, Roc Euro, produces such a dramatic change in SC whine if it's originating from those gears and not something in the compressor chamber.
    Nov 01 2015
    2012 Q7
    FL
    Straight tooth makes more noise than helical.
    2014 S4 P+
    2012 AUDI Q7
    STOCK
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    That's what I would assume and the whine does sound like that of straight cut gears.
    Dec 03 2008
    2018 SQ5
    The stock intake is designed to muffle as much sound as possible
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by OnEaNgRyBuNnY View Post
    Aw, snap! Someone said the magic words!
    Apr 29 2013
    Ottawa
    Huh, cool I guess. RocEuro is a great investment for letting the sound out :D
    Dec 03 2008
    2018 SQ5
    Yeah, it's not that an intake causes more noise, you are just removing all the stuff that helps cancel the sound that's already there
    Aug 27 2008
    Houston Area
    It isn't.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    that hurt to listen to!
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    Quote Originally Posted by jrivera View Post
    That's why us B6/7 S/RS4 guys have supercharger whine . . . those wonderful straight cut gear driven accessories that make so much dang sense "But, your honor, they pack so much power transmission ability into a small and lightweight space!"
    Fitzydood - Greay work. Also, you are funny when you write the same as when you speak.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
    Feb 01 2015
    Lancaster, PA
    Quote Originally Posted by B8_Jim View Post
    It isn't.
    Then where???
