Results 1 to 7 of 7
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    Would you go Oil Pressure gauge over Oil Temp gauge?
    I would. What about you?
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Mar 24 2013
    Oakdale, CT
    Yes, pressure > temp. Low oil pressure will kill your engine faster than high oil temps. Since our oil is liquid cooled by the coolant, if your coolant temp is normal, chances are your oil temp is ok.
    -Adam
    Jul 15 2011
    Boynton Beach, FL
    Word. I just wanted to you to agree with me LOL.
    edit: now is there a place to install an oil pressure sensor? or do I have to make one lol.
    Mar 24 2013
    Oakdale, CT
    You basically install a tee fitting where the oil pressure sensor screws into the oil filter housing. 42 Draft Designs sells a kit to do this.
    -Adam
    Jul 15 2011
    Boynton Beach, FL
    bah, out of stock at the moment. but thanks for the tip Adam!
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Quote Originally Posted by jerseybrian View Post
    I have the 42DD adapter and it works great. Check with any local VW tuning shops that may be around you. Lots of VW guys use this adapter, really common for tuning shops to stock them.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by drewgold View Post
    Cool, I'll check with Eurotech and KMD Tuning tomorrow
