Originally Posted by
poostA4
So in the shortest manner there isn't answer, it's you pick a repair to do and hope you picked the right one.
Blue smoke from burning to much oil, and symptoms of burning coolant, are separate issues with different causes. There are a couple of frequent causes of excess lube oil burning, but only one typical cause for burning coolant.
One reliable way to determine if the head gasket is leaking, is to get a sample of the coolant and have it tested by a lube oil analysis lab for the presence of dissolved combustion gasses in the coolant. Normally, there is zero detectable dissolved combustion gasses in the coolant. If dissolved combustion gasses are detected in the coolant, that is firm evidence the head gasket is leaking.
With regards to the excess lube oil burning and blue smoking, the two primary causes need to be checked to identify the cause for the blue smoking symptom. With this in mind, a high milage engine will have practically a 100 percent chance leaking valve guide seals are partially responsible for higher than normal lube oil consumption and oil burning with variable exhaust smoking under certain operating conditions. In severe cases, the oil lost through the valve guide seals is high enough to result in the accumulation of oily deposits around the turbo turbine housing, due to condensation of partially burned vaporized lube oil in the exhaust. Performing the relevant troubleshooting steps, will reveal the most likely cause for excessive lube oil burning, and the associated remedy required.
If the valve guide seals are not leaking excessively, then the turbo shaft oil seals need to be examined for defects allowing excess oil leakage into the turbo compressor or the turbine housing, either or both causing excess lube oil consumption and associated blue exhaust smoking symptoms.
It is a matter of experienced judgement concerning which troubleshooting procedures are performed before other tests as needed to determine the most likely cause for the existing symptoms.
In addition, if the crankcase ventilation plumbing is plugged up with sludgy deposits, will result in high crankcase pressures that will provoke oil burning from oil being forced past the valve guide and other engine seals. as well as higher than normal oil loss past the piston rings than will occur with normally slightly negative crankcase pressure. Normal crankcase pressure averages a few inches negative water column pressure, or about ~ -0.4 psig below ambient air pressure.
The above described possible causes for the symptoms occurring, assumes the compression test results are within the acceptable limits of the compression pressure specifications with any excessive compression pressure variation due to valve seat leakage compared to compression loss from excessive piston ring and cylinder wear.
