Results 1 to 12 of 12
    Established Member Two Rings i2etributi0n's Avatar
    Oct 28 2014
    Freeport, PA
    Most efficient way to swap an engine?
    So after several months of trying to find something to replace my engine with, I finally have something available.
    I'll be swapping my AMB with an AWM from a Passat.
    What I'm asking is whats the quickest easiest way to swap them out?
    I'm not looking for shortcuts, but the garage I'll be doing the work at has limited time available so I wanna get in and out as fast as I can.
    And, assuming all goes well (because everyone loves an easy job when working on their car), how long should this take me?
    And last question, according to this post, the original poster had an issue with the cv axle bolt pattern being different,
    and someone told him to swap the flanges. OP states his car is FWD. My car is quattro. Will this be an issue I'll be running into as well?
    And if so, how will I got about swapping the flanges? I ask because I haven't done this before and I don't have a manual to refer to.
    [2003 A4 5Sp 1.8T][Problems]
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Really the big question is whether or not you have manual or automatic and what transmission did the donor car have.
    Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
    Sep 08 2015
    Orting, WA
    I have a A4 (AMB) and a Passat (AWM). The general consensus, once transmission type is ironed out is to swap the exterior engine parts from your car to the donor engine. I can tell you that the AMB has a single serp belt, the AWM has two. One drives the AC, the other drives everything else. The A4 has two electric cooling fans, the Passat has one electric and one mechanical (driven by the serp belt), it's reported that the thermostat is different, as is the cooling fan. The PCV system is slightly different as well.
    Oct 28 2014
    Freeport, PA
    Ok, but I'm not using anything external from the AMW engine. I just need the block. Everything external from my AMB is going to be swapped over.
    Will that be an issue at all or should everything swap over just fine?
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    When I did my tip to 6 speed swap I had the engine and transmission out in 6 hours. I had a buddy help me pull it out. Did the install by myself Pull the engine and transmission together imo.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Oct 28 2014
    Freeport, PA
    6 Hours isn't too bad. So, going by your time, assuming all goes well, I could possibly get it done in a day..
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by i2etributi0n View Post
    In a day!! Maybe with 2 others. Take your time, nothing worse than forgetting to install something you left out. And was probably easier 3 hours ago when.....
    I know about this!!!!
    04 B6 A4 USP 2.7t
    Oct 28 2014
    Freeport, PA
    I understand taking my time, but like I said, the garage access is limited so I'm looking for tips on how to make this as seamless as I can. :P I'm sure I can get by taking 2 days to do it.
    Which I just remembered, I have a new heater core I need to install as well.. More time!
    Jul 28 2014
    SACRAMENTO
    Haha
    Good luck. I studied for 8- 6 moths before taking the plunge. Post up your endeavors!
    04 B6 A4 USP 2.7t
    Oct 28 2014
    Freeport, PA
    Quote Originally Posted by 19jdog View Post
    Haha
    My car hasn't been running for about that long. lol. I really need to get it back on the road!
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    If you have a lift and air tools / the proper tools for the job, you can get the engine out in about 3 hours especially if you have help.
    Audi Club Bay Area
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Quote Originally Posted by Furly View Post
    This. Easy peasy if you know what needs to come off and what doesn't.
    1.8t's are the shit for engine pulls.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
