Results 1 to 17 of 17
    Mar 26 2012
    Charlotte, NC
    How to Disable Fog Light Error Check with VCDS?
    I've seen this on the forum and tried it. I know it's for reverse but it didn't work. how do I do it to stpo checking for Fog Lights?
    Thank you!
    I have disabled the reverse light bulb error check with VAGCOM. Now running LED bulbs without any issue.
    Here are the steps:
    Module 46 Central Convenience > Security Access 16 > 16017
    Adaption 10 > Channel 181 > Convert your decimal number to binary (for example my default number in decimal is 65535, converted to binary = 1111111111111111), then change bit 10 and 11 from 1 to 0 (my new binary value becomes 1111001111111111, which is 62463 in decimal) > Enter the new binary value > Test > Save
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    They do make LED Error free Reverse lights BTW...
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by AUDIMAN33 View Post
    Yea if you wanna pay 50 bucks for a pair.
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jan 11 2014
    Quote Originally Posted by JeriQo View Post
    I did lmao, I cant say I even regret it.
    Mar 26 2012
    Charlotte, NC
    Sorry guys I wasn't clear.
    I just took out the 55W Fog light Bulbs and put in a projector and a 55W HID. I'm getting an error saying the bulbs are out but they work. The annoying yellow sign on the dash when i turn them on and off sometimes. I want to get rid of the check. (Don't worry I'll post the results of this soon ;)
    Mar 21 2015
    So did I and don't regret it.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by SDF1 View Post
    Edited my first post
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Mar 26 2012
    Charlotte, NC
    Quote Originally Posted by Gunnark100 View Post
    http://www.audizine.com/forum/showth...1#post11559692
    Mar 26 2012
    Charlotte, NC
    Anyone know the code in VCDS to stop the bulb check?
    Mar 26 2012
    Charlotte, NC
    Bump
    Jul 08 2015
    Mar 26 2012
    Charlotte, NC
    I have VCDS. What do i have to change?
    Mar 26 2012
    Charlotte, NC
    BUMP again...
    Mar 26 2012
    Charlotte, NC
    Bump!
    Established Member Two Rings Dirty_Bourbon's Avatar
    Nov 06 2015
    2021 GLB
    Morristown, NJ
    Giving a free bump here but i have a question.. does anyone have a tool i can borrow. Literally want to amend a code or two and dont want to buy a tool for that.. if perhaps a kind someone has already and could lend a helping hand..
    -Want to run brighter DRLS in parking mode ( i dont ever use my headlights so diming leds is not the best- i run DRL and Yellow Fogs 24/7
    grazie
    B9.5 S4 Quantum Grey/Grey
    +JB4 Module (Map3 93 oct)
    +VPS Mid Muff Delete
    +CTS Inlet paired with Roc Euro Intake + ECS Silicon Coupler
    ________________________________
    In Remembrance:
    B9 A4 SLine B/Br
    B8.5 A4 SLine Competition B/Optics[/FONT]
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    Quote Originally Posted by Dirty_Bourbon View Post
    grazie
    Did you ever get the code for Vagcom?
    BMW M850i
    Senior Member Two Rings jorte014's Avatar
    Apr 16 2013
    Mercedes-Benz ML 350
    Coral Springs, Florida
    Also interested in the code for the fog lights...
    2014 S4 6MT - Milano Red | Premium Plus | Black Optic | Bang&Olufsen
