Results 1 to 8 of 8
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    Timing Hall Sender tool question
    Hey all,
    I'm in the middle of doing my timing service on my car and I'm currently torquing the camshaft bolts to the final torque. I tightened the left side bolt on the drivers side head, followed the Bentley manual and removed the camshaft holder tools. Went to put the hall sender tool back on and it didn't line up with the bolt it sits on top of on the left side.
    Below are some pics.
    My question is should it be off a little bit. I can get the tool back on if I move the adjuster then it lines up. Is my timing off a tooth when I installed the mech adjuster?
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    As long as you had no problems torquing it. The mechanical adjuster doesn't have to sit in a certain position. As it is not timed. Just make sure it's seeded on the electronic adjuster.
    I had a hard time getting the passenger side adjuster seeded. Took me an hour, since it's jammed in next to the guide.
    Sent from my SM-G900T using Audizine mobile app
    Nov 16 2013
    Lower NH
    Quote Originally Posted by bmwpower603 View Post
    sweet thank you, ill have to double check to make sure its seated. pretty sure it is
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    so you're saying that your cam locks are in and the cam adjuster tool doesn't fit anymore ?
    Nov 16 2013
    Lower NH
    Quote Originally Posted by jakeoboy67 View Post
    yes off by a little, look at the pictures and you'll see
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Feb 18 2014
    Arizona
    It looks like the round part of the tool is sitting at an angle on the adjuster, I did that before without realizing it and had this problem, but then it lined up correctly when I had the round side placed flat against the cam adjuster. It can be a little finicky getting it placed correctly
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    are you rotating the engine with the chain tightened by the 2 plastic "wedges" ,
    Nov 16 2013
    Lower NH
    i had one in, it popped out when i rotated the engine.
    >04' S4, Nitrous
    >01.5' S4 dps, tune
