Originally Posted by
BCsniper
How so?
If you are able to get a bigger tire on a 17" wheel, why are you losing handling response. You can get a tire with the same width, even more meat on it, with a wheel that's more lighweight. That sounds MUCH better to me than so many people here that like to run heavy 19" wheels with stretched or skinny-ass tires
As Noob5 points out I was referring to increasing the sidewall, going on the assumption derived from OP's info.. In other words reversing the +1 factor of a larger diameter wheel fitted with a smaller profiled tire. Going from an 18" with a 235-245 / 40 to a 17" fitted with a 235-225 / 45-50 will affect handling in a loss of response and probably other factors.
The S4 is a lot heavier up front than an A4. It tends to understeer and increasing tire profile while at the same time reducing width will result in increasing understeer.
As for 19's, I am not a fan of them for the B6. greater choice of wheel applications in an 18, greater choice of tires and overall less expensive...
As for the argument that a 17" wheel is lighter than an 18" . That is highly dependent on the quality /brand of wheel to be fitted. There are many aftermarket 18" wheels that are far lighter than oem 17" wheels.. That is an easy solution.
For my S4 I currently run oem 18x8.00 shod with 245/40 Conti DW's. This summers set up will be 18x9.00 with 255/35 Conti's. ( 8.5 width is also an option but 9.00 is the preference. )
