Results 1 to 7 of 7
    Jul 23 2015
    Fergus falls
    Coolant temp higher then normal
    Hello, I am having problems with an overheating issue on my Audi the past couple months it was doing alright I'm thinking because of the colder weather. Today was bad though I was driving from Fargo, and there was alot of wind, obviously. the gauge went passed the halfway mark and then maintained temperature at the 5/8 spot. I got worried so I slowed down and that seemed to help but it sat in between the 1/2 and the 5/8. I replaced the thermostat, the head gasket, the cylinder head, the pvc system. I had replaced those parts back in the fall so i never really noticed it until it had to fight with the wind in the warmer weather. everything else seems to be working fine to my knowledge the a/c works the heater works. i opened the coolant reservoir to see if the waterpump was bad but i got pressure there. I don't want to keep driving it knowing that this will happen again and maybe crack another cylinder head.
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    CTS sensor
    Jul 23 2015
    Fergus falls
    That was changed as well
    Dec 05 2007
    What year car? B6 has two sensors, while the B5 lower one is only an auxiliary fan switch. Which brings up, do you know if your auxiliary fan kicks on when it needs?
    Jul 23 2015
    Fergus falls
    It's a 2001 so a B5, I do not know if the fan kicks in or not
    Apr 20 2016
    brisbane
    Had the same problem check your fan control module changed mine as well as the fans all good now.
    Sent from my SM-P350 using Tapatalk
    Jul 23 2015
    Fergus falls
    alright sorry for not replying right away ive been busy with school stuff thanks for the input guys.
    also thinking bout trading a 92 bmw 525i for 99 vw jetta 1.8l any thoughts it would be easier to interchange parts for my audi thoughts?
