The reason I picked up the block is that I had my entire cylinder head replaced under the cam follower warranty last year after a catastrophic cam follower/fuel pump failure. The dealer refused to replace or even check the crankshaft, bearings, block, etc. and I have been concerned since then that my main bearings/rod bearings/balance shafts may have been damaged by debris and are a ticking time-bomb.
In my mind, it seems like a bit of a waste to have a brand new shiny head sitting on a block with just over 100k miles on it and being fed by an oil pump that could destroy it without notice. Especially given that there may also have been damage to the crankshaft/bearings from the cam follower failure.
The big picture: I don't have plans to got BT or make any kind of crazy horsepower. My goal is modest gains while maintaining reliability and longevity. Likely the limit of my performance mods would be JHM Stage 2 HPFP programming and an upgraded FMIC. (On top of the usual HFC, exhaust, etc.) I currently own the JHM stage 1 tune but have not installed it yet for fear of awaking the demons that lurk inside my block.
My original plan was to track down a matching crankshaft for the block I acquired and have the short block rebuilt to OE spec with the possible addition of a 1.8t oil pump (I also picked up a used 1.8t oil pump from @CanadianA4B7) to replace the OE 2.0t oil pump/balance shafts. I'm not 100% sold on the 1.8t conversion but am seriously considering it.
This way, I could have the new block installed at a time of my choosing (limiting down time to only a day or so) and effectively have a brand new engine that I won't have to worry about for years.
I have also been considering modest build options too:
- Looked into doing a 2.0 to 2.1 stroker but talked to a few builders who advised against it. Sounds like there are better routes to take if I'm going a build route.
- I think boring the engine is more of a cost/investment than I want to take on so not really wanting to go that route.
- Updated internals? Is there much benefit to going with something like IE drop in rods, rifle drilling and upgraded/coated bearings with OE pistons? Or is it overkill to upgrade from OEM if my plan isn't to go beyond a stock turbo and a JHM Stage 2 tune? Can OEM rods be rifle drilled?
- Any other recommendations?
A final option would be to have the block rebuilt and put into storage, ready to go for the day that may or may not come with the failure of a bearing or oil pump. Obviously there is some higher risk of damaging the head with this approach but maybe my block is just fine and has another hundred thousand miles left in it!
In the end, cost is a big factor, with my main goal being to have a reliable daily driver with an engine that is robust, can withstand some spirited driving, and will buy me a few hundred thousand more miles of worry-free driving.
I know this is a long post, but hopefully the experts out there can advise me on the best direction to take. Thanks for any feedback!!
