Results 1 to 20 of 20
    Apr 11 2016
    New Jersey
    Question Pure Protection Warranty - Claim Issues or Problem Free?
    I have read numerous people have purchased the Audi Pure Protection Warranty's (Underwritten by Fidelity). I have seen the platinum level mentioned. But, what I haven't found much on this forum is if people have had issues getting claims paid or if it has been a worry free process. The other issue is many have the extended warranty but are still covered under their factory warranty or CPO, so they have no history.
    So... Is there anyone who has the plans, used these plans and have had good things to say about them? Will hear the bad too but curious if there is any good. Especially as it comes to anything major one may have had tried to get covered under the warranty.
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    There should be no issues, I have the platinum coverage.
    - iKe -
    2011 S5
    2011 A4 Avant
    Jan 03 2013
    Baltimore
    I have the platinum coverage as well and will be bringing it to my local shop for a list of items to be checked on and hopefully covered. The shop indicated they have worked with them in the past and the process wasn't terrible. The time needed for the initial inspection by the shop, submittal of a claim and possibly an additional inspection by their warranty folks makes the whole process a little longer. Add in the time to order parts and install, they told me it would be about a week. Thankfully, I will be out of town for a week while they have my car. I will report back when it's all done in early May.
    Sent from my XT1096 using Tapatalk
    Jan 03 2013
    Baltimore
    I just got off the phone with the shop and they have submitted the following to be covered: passenger and driver engine mounts, valve cover gasket/seal, front control arms, driveshaft (has play), rear diff mounts.
    They said the inspector should be out tomorrow. I will post when I get a final word.
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    I have the platinum coverage and had a valve stick open after initial warranty expired. I also have a heavily modified car. Took the car to the audi dealership and got the repairs done with no problems. Repairs were covered without need for an inspector to check out the car. Only paid $100 deductible.
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by pwdrskr View Post
    did you purchase this platinum coverage from dealer or fidelity?
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jan 03 2013
    Baltimore
    That's good to hear. I have mine at an Indy shop, so perhaps they prefer to send out folks to places that are not Audi dealers. The shop has worked with fidelity a bit and has not had issues, they said these items shouldn't be an issue to cover.
    Side note-had anyone had to replace the drive shaft? They told me it's a 1900 part.
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by JeriQo View Post
    I bought the warranty at the same time I bought the car at an Audi dealership
    Jan 03 2013
    Baltimore
    Same with me, included in the financing.
    Aug 21 2010
    Carlsbad, CA
    I should add that I am normally one to avoid any extended warranty. These are typically designed to maximize profits for the seller at the expense of the consumer. Once upon a time I worked as an electronics sales rep and learned that the mark up on extended warranties are insane.
    That said, these cars are expensive to fix and with my recent experience with the valve I am glad I picked it up. Particularly as the mods I've made had zero impact on coverage. The repair cost me $100 for something that would have been >$1000. So far I've spent more for the warranty than the repairs I've made but with my intention to keep this car for quite a while I feel there is a significant probability that I'll use this again.
    Also, getting the repairs done at the dealership was smooth and transparent to me. I dropped off the car and it was repaired in the same time frame as if I were having it done under the original manufacturers warranty. My service advisor handled everything. No claims or reimbursement on my part required.
    Jul 08 2015
    just purchased a platinum coverage from troy. he offered half of what audi was charging so thats a no brainer.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Glad to hear you got it all taken care of!
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Apr 11 2016
    New Jersey
    Guess it depends on what you mean as no brainer. Compared to dealer I get but the cost is another. What was the cost and term?
    Jul 08 2015
    Quote Originally Posted by imt View Post
    6yr/60k platinum coverage w/ $100 deductible. the miles adds on to your current odo reading. --- so im covered to 76k
    Apr 11 2016
    New Jersey
    I'm assuming then this isn't your 2012 A4 listed, with only 16K current miles.
    Jul 08 2015
    it is.
    correction: to 74k.. 14k miles currently on the b8
    Jan 03 2013
    Baltimore
    Quote Originally Posted by elscotto80 View Post
    All of the above work was approved except for the control arms. They said they wouldn't cover that because I am lowered. Oh well. 5 day wait on the propeller shaft ad it's coming from Germany.
    Senior Member Two Rings inception's Avatar
    Mar 19 2015
    2018 Q7 3.0T
    phoenix arizona
    Audi Pure Protection warranty is probably the best out there. I have had heavily modified A4 and RS4 and now i am getting ready to get my current A4 on it. My current car is Flagged TD1 with Audi Long story but i have talked to my service advisor who i have had for 8 years and obviously since i was flagged TD1 was wondering if i should get it.
    i confirmed again with the manager and Audi Pure Protection has no way or know if your car is Flagged TD1.
    i am going forward to get the extended warranty.....
    To respond to some of the questions....
    yes if you get the warranty thru the dealer they will take care of you. Mind you do most of my maintenance at the dealer but use local shops to modify my cars. In the past with my A4 ans RS4 my dealer has gone to bat for me and have replaced many including transmission on my B7 A4 and also and Engine on my RS4... and mounts and many little things...
    so to say the least if you have it and have a good relationship with your dealer do it and you will not regret it....
    2018 S6 APR Stage 1
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Bump. What coverage does everyone have? I have the Platinum 7yr/75k mile. Anymore experience with dealerships?
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
    Jan 03 2013
    Baltimore
    I got the platinum, up to 100k and 8 years from the in service date. Just used it and got them to approve about 4,500 in work. Paid about 2,500 for the warranty.
