Hi guys,
cpl weeks ago i replaced my fuel pump. to get it out i banged on the pump pretty hard eventually getting it to turn and come out.
now i have the following issue: leaking gas!
- when i fill up all the way, gas is literally dripping from the passengers side. like dripping dripping, enough to get a large puddle within two minutes.
- the area around the gasket is wet
so i will be replacing the gasket and doing a better job of seating it.
how can i get better access to the tank to see if caused a fracture in the tank or if its a hose issue? have you come across a DIY for dropping a tank and inspecting it?
