    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Throttle body gasket part #s
    Anybody have part #s for both of the gaskets that go on the intake manifold elbow. Replacing my throttle body gasket and 1 looks different from the other.
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    This is the P/N: 079133073A for the gasket indicated here:
    ECS has it
    Is that the one, or are you looking for the one closer to the IM with that extra half circle shape:
    If so, I'm not sure, I might have it somewhere, would have to do some digging
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Nov 11 2008
    One closer to the manifold. Pic on bottom. I found it though part # ends with b
    Established Member Two Rings trendster09's Avatar
    Feb 25 2009
    vancouver bc
    Quote Originally Posted by S4orgy View Post
    You got that part no? I need this gasket can't find it anywhere. TIA
    B7 S4 6MT(current)
    B6 S4 6MT(dead)
    B6 A4 3.0TIP(sold)
    Nov 11 2008
    079133073b
