Results 1 to 6 of 6
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    What does this LCD icon mean???
    Curious to see if, anyone knows what the below LCD icon (Steering wheel with an exclamation mark) means on a B5 S4. G85 Steering wheel angle sensor problem or clock spring dead? I have searched the internet and have come up empty. Thanks in advance.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Weird, on newer cars that would have to do with electric power steering. I didn't even know our cars had this. Check the cluster coding, I think something might be off.
    May 20 2010
    I vaguely recall seeing that in a buddy's GTI post-accident fix. I think it's the steering angle sensor. Did you do any work recently that would have affected it?
    Oct 26 2011
    CA
    Tip to 6 speed swap and a bunch of other stuff. Scanned it and I get the G85 steering angle sensor intermittent. Want to make sure before a drop $400+ on a new one.
    Jul 04 2012
    Woodbridge, VA
    It means "put your hands back on the steering wheel or else you'll fall out of the ajar door" ;)
    Nov 05 2009
    Denver
    Quote Originally Posted by xalents23 View Post
    They rarely fail so a used one should be good to go. Just make sure it's centered before you
    install it otherwise you'll tear the printed ribbon the first time you turn the wheel
