Results 1 to 32 of 32
    Apr 10 2012
    2003 Audi A4 1.8T Quattro
    Fort Worth,TX
    Just ordered a Blauparts timing belt kit, do I need to rent the tools?
    So I am about to embark on my first timing belt change. I ordered the kit from Blauparts, and they have the optional OEM tool rental, of the howtos I have read it doesn't seem like its necessary, Any thoughts from you folks that have done this job before?
    2003 A4 1.8T Quattro Auto, Custom Stage1 tune, N70, 550cc Fuel Injectors, B7 console (with cup holders!)
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    You don't need any special tools. ECS tuning has a great DIY:
    http://bd8ba3c866c8cbc330ab-7b26c6f3...ingBeltDIY.pdf
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    I'd recommend the tools it makes life easier.
    "Beep beeeep bloop boop" - R2D2
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Here's a nine year old post that is worth a read: Clicky click ®
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    That is an excellent tip from OG above!
    It sounds so foolproof that I'm even tempted to forget about trying to rotate the engine by hand to line up the timing marks.
    But this will be my first TB change too (in the next couple of weeks), so perhaps extra caution is warranted. :)
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by eljay View Post
    Since this is your first TB change definitely align then factory marks just for your own peace of mind. But beyond that think about the rationality of match marking the belts. If you put the original belt back on with the marks aligned it's going to go back exactly as removed. As long as you transfer the belt marks the new belt will be the same.
    A word of caution. The belt marks are not going to align after one rotation. If you continue to rotate the engine they will realign after somewhere around 50 rotations. The marks index forward with each rotation and will eventually realign. The factory marks should realign after every second crank rotation.
    So don't freak out with your cam/crank/belt marks when you rotate the engine. Be confident in your original belt/pulley alignments and go forward with confidence!
    Apr 10 2012
    Fort Worth,TX
    great tip on the marks for the TB, Will definitely be doing that! Sounds like extra piece of mine compared to the factory marks. My biggest worry I guess is after you take off the pullys you move the camshaft and it gets it out of alignment with the marks.
    Apr 10 2012
    Fort Worth,TX
    Looks like I will be doing this job tomorrow as I have to get the rental tools back pretty quickly. When you guys do this are you putting the front in Service Position? or swinging the fans and everything off to the side? I have the tools to put it in service position.
    Aug 13 2015
    NS
    Quote Originally Posted by daverdfw View Post
    I am planning to do it this weekend! And I plan to swing out the carrier for more access. I think that I am keeping the wheels as I don't have the bottom engine cover and I think I can just turn the wheels side-to-side when on jacks to access the fender liner screws.
    Good luck and report back!
    Apr 10 2012
    Fort Worth,TX
    same here on the skid plate. I should be able to get the bumper off pretty quickly. Only part that makes me nervous is lining up the marks, and what to do if the marks move while you are working on it.
    Dec 28 2006
    Western Maryland
    If you mark the belts properly it doesn’t matter if the cam moves a little in one direction or the other. As long as you make sure the belt marks align with the cam/crank marks you will be maintaining the proper spacing between the cam and crank. If the cam moves a little you may have to tweak the crank slightly in one direction or the other to realign the belt paint marks.
    Again, as long as you align the belt/cam/crank paint marks it’s virtually impossible to change the cam/crank timing from what it previously was. Don’t overthink it!
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    If you are talking about access to the six bumper to fender nuts it is easier to access them by removing the headlights.
    http://www.a4mods.com/index.php?page...erremoval.html
    Aug 27 2013
    Philly
    Quote Originally Posted by Let it snow View Post
    I agree. Also, I wish the 3.0 had key'd cam gears. It would make things easier for sure.
    Apr 10 2012
    Fort Worth,TX
    yeah I see what you are saying, I am sure I am making it more complicated than it really is, thanks for the advice!
    Aug 27 2013
    Philly
    Yup. This image really shows that its full proof to mess up the timing on an engine with locked cam gears.
    Aug 13 2015
    NS
    Yep, I will be removing the headlights.
    Apr 10 2012
    Fort Worth,TX
    so it looks like in order to swing the carrier over I have to remove the transmission cooler lines? Anything I need to be worried about when doing that?
    Established Member Two Rings Chris M's Avatar
    Jan 15 2011
    69 Bronco
    Tucson/AZ
    i just did this timing kit last month. no special tools needed. you can swing the carrier over without removing the lines, although you would have some more room if you did. take the spark plugs out to turn the crank easier. line up the cam and harmonic dampener to the marks before removing the belt. i had to adjust the new tensioner a couple times after rotating engine a few times before it stayed in the set tension mark on the pulley. it takes a while but nothing complicated. good luck
    Apr 10 2012
    Fort Worth,TX
    Quote Originally Posted by Chris M View Post
    hmm ok, just seems like in the DIY on here they are able to move the carrier totally out of the way, so you are saying you didnt remove the Transmission lines on the left side of the radiator?
    Apr 10 2012
    Fort Worth,TX
    so just as a quick sanity check, I have the top cam sprocket lined up with the valve cover mark, I took a paint pen and made 1 mark on the cam sprocket and 2 on the crank, does this look right?
    Just wanna check before I take the belt off.
    Aug 27 2013
    Philly
    Looks good to me. Pull the belt off, transfer the marks to the new belt and install it.
    Dec 28 2006
    Western Maryland
    You got it!
    Jan 15 2011
    69 Bronco
    Tucson/AZ
    i was only able to swing the carrier about 30-45 degrees but enough to work on it. and proped the other side up on a box.
    looks good. then when the pulley and cover is back on you can check the marks on it.
    Apr 10 2012
    Fort Worth,TX
    thanks everyone! I really appreciate your help and patience. What I ended up doing to get more room was disconnect the power steering cooler, and then I left the transmission lines on the radiator. Then I swung it over to the passenger side.
    Apr 10 2012
    Fort Worth,TX
    also it looks by the red color on the water pump it was leaking coolant, hence the pink/red color on it.
    Apr 10 2012
    Fort Worth,TX
    Success! Took about 7 hours, and everything is back together and running great! No leaks or issues. Thank again EVERYONE for the help, I really appreciate it!
    Dec 28 2006
    Western Maryland
    Sweet! Nice job. Feels good, doesn't it!!
    Apr 10 2012
    Fort Worth,TX
    yea feels great. One thing i just though of, I got the new Litens tensioner, I got it lined up in the notch, and I don't recall if I checked the notch after I rotated the crank twice. Is that anything to be worried about?
    Dec 28 2006
    Western Maryland
    You should be fine. Now relax, drink a beer, and enjoy your handiwork.
    Apr 10 2012
    Fort Worth,TX
    thanks for all the help! you guys are a lifesaver!
    edit: I pulled the top cover of the timing belt off and used my mirror, and the tensioner notch is still aligned. SO at least I could check it without too much effort. Thanks again!
    Apr 10 2012
    Fort Worth,TX
    just for reference, you are supposed to get the green dot on the right inside the gap on the left.
    Aug 13 2015
    NS
    Congrats!
    I am about to tackle mine. I have the regular old style tensioner I believe.
