Results 1 to 17 of 17
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Watch "Bad coilover shock audi A4 b7" on YouTube
    https://youtu.be/vfHyHlf3svg
    Sent from my C5306 using Tapatalk
    Ivan
    Aug 20 2013
    Miami
    1 year old on my street edge coilovers...this is the rear drivers side did my shock go bad????
    Ivan
    Aug 20 2013
    Miami
    Quote Originally Posted by dalmation53 View Post
    Uhhhhh.....Calling alll suspension masters...I repeat calling all suspension masters..... I need suggestions please!
    Ivan
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Cannot comment on the shocks, but those recording skills!
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Aug 20 2013
    Miami
    Quote Originally Posted by gotboost View Post
    LOL I was with one left on the car pushing down and the other hand recording that's why is moving up and down..
    Ivan
    Jun 26 2015
    2008 Subaru Tribeca
    Lancaster, PA 17603
    Try again OP, it is impossible to know what is happening in this video.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Wow, my head is spinning from watching that video.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Aug 20 2013
    Miami
    Guys sorry for the shitty video i'm moving the car up and down and is making that noisy only in the rear drivers side. is causing that squeak is not Quattro.
    Ivan
    Mar 08 2015
    Alaska
    With all the time spent on this thread you could have have just went out and looked / listened and figured this problem out yourself. There is no one on this forum..... or anywhere on the interenet that can properly diagnose your car. That's all you.
    My advice, have someone bounce your car while YOU feel around for the source, you should be able to find it in less than a minute.
    Sent from my SM-G925I using Tapatalk
    Aug 20 2013
    Miami
    Quote Originally Posted by 907DAVE View Post
    I wasn't asking for a diagnostic i was asking for suggestions where to look at. there's only 3 things bump stop, strut mount or shock. but instead of taking everything apart and buying for no reason i like to know where to look.
    Ivan
    Mar 08 2015
    Alaska
    Start with looking at those 3 things lol.
    Sounds like a sway bar bushing to me, but I'm nowhere near your car.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    My suggestion, take your wheel off and rest the axle on a couple jack stands. Then you can feel around better
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Aug 20 2013
    Miami
    I think you hit the jackpot. maybe you are right. I only have 20k miles on this coilovers and the fronts have been through hell and no sign of wear and the rears are babied and this happens.. I shall check my sway bar bushing..
    Ivan
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    You could remove the shock to rule it out
    Aug 20 2013
    Miami
    Quote Originally Posted by AJacksA4 View Post
    Don't i have to remove the spring too?
    Ivan
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    The rear does not have the spring over the shock...
    B8.5 3.0T/ B5.5 1.8T
    Aug 20 2013
    Miami
    I found my problem guys. sorry for strocking my shock like that..hahahahahaah
    https://www.youtube.com/watch?v=e_8klOBUSR8
    Ivan
