Results 1 to 8 of 8
    Established Member Two Rings stussy2870's Avatar
    Apr 04 2016
    Butler PA
    Help with this bolt/thing
    New Member, thinking about painting my Calipers-- Saw these, loved it.. what i dont know/understand is - Does this bolt or post thing come out of the brakes, or do i need a special tool- etc??
    I've searched and asked in the wheel caliper paint post/thread.
    Surely Someone has this answer-- sorry i'll stop calling you shirly. ;)
    Thanks
    Paul
    2015 Premium A4 Sline 6M/T, Dinan PiggyBack, K&N Typhoon Intake, Comfort Drop Spings, Niche Targa 20x10, RS4 Grill, Slotted/Dimpled Rotors and some G2'd Calipers
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Those hold the pads in place. The 9th picture of the thread pasted below will give you an idea.
    http://www.audizine.com/forum/showth...?highlight=DIY
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Apr 04 2016
    Butler PA
    Thanks Baked but I've see this thread and already and i dont see anything in here that answers my question- How do they come out or was the OP from the Caliper painting thread THAT obsessed w/ detail that he polished and masked off that post??
    Established Member Two Rings Ego_Trip's Avatar
    Apr 01 2014
    Utah
    Quote Originally Posted by stussy2870 View Post
    I just painted over mine, they had corrosion anyway. I've also since done a pad and rotor replacement and they don't need to be removed to do it. Not sure how you'd remove them...
    [2011 Audi A4 2.0T Prem. + Quattro]
    May 20 2010
    I"m wondering if you can get a large enough external torx socket that would be able to remove it... if it can be at all.
    Oct 23 2014
    _
    Sorry, I missed your question there. I am not sure of the exact tool that gets used, but according to the link below, it is possible but they advise against it.
    http://workshop-manuals.com/audi/a4_...kes/page_6372/
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Apr 04 2016
    Butler PA
    Well there you have it.. That OP has some masking and polishing skillzz.. lol - Thanks for the help fellas.
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Quote Originally Posted by bakedziti View Post
    CAUTION!
    Brake fluid is poisonous. NEVER siphon brake fluid with your mouth!
    Wow, they really had to put that in there.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
