Results 1 to 11 of 11
    Registered User Four Rings
    Oct 27 2007
    NA
    Deals of the week! New G6 3000K Deep Golden Yellow LEDs fog lights w/3000lm H8 / H11
    Hello AZ!
    We have G6 3000K LED's for H8/H11 with up to 3000 lumens on special sale.
    Priced at $89.99 with free shipping in the US and Canada.
    These LED's use 'PHILIPS LMZ Chips' to produce very deep golden yellow with extremely bright lights without blinding other traffic.
    As we always do, we tested it by leaving it stay lit for 10 days straight and it survived from our strict testing process.
    We installed it on a customer's Porsche Macan and it definitely added a aggressive look to the ride not cheap JDM wanna-be look.
    We compared it to Philips 2700K LEDs.
    Philips 2700K LED gives deeper yellow look that is close to amber like color while G6 LED gives brighter yellow.
    See the comparison photo.
    If you have any questions, please feel free to ask via PM, email at [email protected] or call us at 1-888-579-5917.
    Thanks,
    Established Member Two Rings Vaks's Avatar
    Nov 20 2015
    Do you guys have color matched fogs for the B8.5? As close as possible to the oem headlights/drls
    Current:
    2013 Audi A4
    AudiTrueNorth | Ibis White | Quattro | RS Grille | RHO Plate | BlackVue | APR Carbonio Intake | GFB DV+ | KW V2 | AG Wheels
    Veteran Member Four Rings Alex1188's Avatar
    Mar 10 2013
    Forest Lake, Minnesota
    I'm curious, I see a lot of people putting these in reflector housings. I would be concerned of blinding on coming traffic...
    Is this safe for a reflector housing?? Also is the cut off of the light nice or is there some glare? Can you put these or any of the other led bulbs you guys offer in a low beam headlight?
    Oct 27 2007
    NA
    Quote Originally Posted by Vaks View Post
    You can use these.
    http://www.hidconcept.com/h8-mautoli...headlight-kit/
    It gives closer match to your LED DRL but I wouldn't say 100% match.
    Another option is to order these 6G LED's and try different color filters to find the closest match color since there are 4 filters included.
    If you have stock 4300K D3S bulbs on low beam, I would recommend upgrade them to Philips X-tremeVision HID's that would give 5000K color (initially 4800K and turns to 5000K after about 200 hours of break-in time).
    Thanks,
    Oct 27 2007
    NA
    Quote Originally Posted by Alex1188 View Post
    If you look at the photo of the light where the LED chips are located, you would notice that it has inner curved portion, which is designed to distribute lighting output instead of blinding oncoming traffic. Although many customers ordered these, we haven't received any comment stating that it's blinding oncoming traffic or beam pattern not shining on the ground.
    For driving lights, if you currently have halogen lights, I would recommend using HID lights instead of LED's since HID lighting still gives great amount of light output than LED's.
    Established Member Two Rings 99r6's Avatar
    Dec 03 2015
    Wichita
    Are these error free?
    2011 A4 B8, 1985 E30 (M50 Turbo), 2002 Ram 1500 (Lifted + 35"s), 2015 Grom
    Oct 27 2007
    NA
    Quote Originally Posted by 99r6 View Post
    We confirmed that it doesn't trigger error message.
    Buncha motorcycles
    Memphis, TN
    So no codes with the led on b8.5 running h8s?
    Oct 27 2007
    NA
    H8S? They use H8
    Buncha motorcycles
    Memphis, TN
    Sorry, there was supposed to be an apostrophe there. So the LED H8's run fine on the B8.5's without a code?
    Oct 27 2007
    NA
    Quote Originally Posted by Papachristou View Post
    correct. no problem on B8.5
