Results 1 to 8 of 8
    Junior Member One Ring
    Apr 11 2016
    US
    Adding AUX input to Symphony II (not II+)
    I recently bought my first audi (2005.5 a4 2.0t quattro) and am looking to add an AUX input to the original Symphony II HU. I'm aware that there are "plug-and-play" options that are compatible with the Symphony II (e.g., BlitzSafe, etc.), but I like to DIY and would prefer to not shell out $60+ for an AUX input unless absolutely necessary. That said, I've done some research and have a couple questions regarding the DIY options.
    Unfortunately since I have the II and not the II+, I cannot simply add an AUX jack + VAG-COM the EXT source has described here. This leaves me with two options (unless I'm missing something):
    1. Modding CD Input - This guide mentions that an external CD changer is required, which I don't believe I have (CD inserts right into the HU on the Symphony II, and I don't think I have the 6-disc changer). However, does anyone know of a way to do this mod without the CD changer? Surely there should be a way, as the audio from the CD must still input into the amp, speaker out, etc. in the HU (although this may be PCB level connections rather than external wires). I don't have the keys to remove the HU so I haven't been able to check for myself.
    2. Modding SAT Input - I've heard the SAT audio can also be spliced to add an AUX input, but I'm not 100% sure if my car is wired for satellite radio. When I press the SAT button, the display on the HU says "Call 1-800-SIRI" or something along those lines - does that mean I'm wired in? Again, I don't have the keys so I haven't been able to see for myself.
    Lastly, can anyone with experience doing the CD/SAT mods comment on the AUX sound quality? I currently use a cassette->3.5mm plug to play music from my phone, and it sounds really distorted at high frequencies/volume. If these mods don't offer better sound quality, I guess there wouldn't been any reason for going through the effort (aside from the aesthetic improvement).
    Thanks in advance for any help!
    Apr 11 2016
    US
    Also, I've considered upgrading to the II+, but I've read that the upgrade causes quite a bit of AM/FM distortion due to the antenna type mismatch. Is this accurate, and is there a fix? Reason I ask is that I've seen a few II+'s on here/craigslist for pretty cheap.
    Jan 06 2012
    Chicagoland
    this should work with phone cable and gives you an aux input as well: http://enfigcarstereo.com/ENFIG_AU2_IPDU_AUX.html
    note that I have not done this yet, but have been talking to enfig about this same issue with the symphony II
    I have a symphony II+ but I did not care for the radio reception issues and its sound.
    my 2 cents.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by emptys6gt3 View Post
    my 2 cents.
    I used a similar kit on mine, sounds great and is plug and play. Wouldn't add aux any other way after going this route.
    2007 Porsche Cayman | 5MT
    Feb 08 2012
    Dallas, GA
    Quote Originally Posted by Ashtonts View Post
    Second this. I have the DICE i-AUDI-r version (which isn't as nice as this), but I bought it way back in '10 and the options were more limited. I am not sure this one existed.
    Feb 16 2015
    I spliced into my sat input with a self switching aux jack and the sound quality is great.
    I have heard you can trick the head unit into thinking that there is sat installed by putting a resistor across the the non audio inputs from the sat box, but I dont know for sure nor so I know the resistor value.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Apr 11 2016
    US
    Quote Originally Posted by gonemtbiking View Post
    Awesome, do you know if there's a way to easily tell if you're wired for sat (i.e., without taking the radio out)? As I mentioned in OP, when I press the sat button a "call sirius" message pops up, but I'm not sure if this is any indicator.
    Feb 16 2015
    I would say look for the sat module located in the trunk (forget where exactly). Although mine never says to call Sirius even though I don't have it activated, so guessing you don't have it. But doesn't hurt to check
