Results 1 to 8 of 8
    Mar 10 2016
    Cannot change date/time
    Hello all!
    I recently disconnected the battery in order to install a new headunit for my B7. In the process of trying to remove the instrument cluster (after removing the two screws, I noticed that the wood trim somehow was positioned on top of the lower left instrument cluster trim- thereby preventing me from doing so), the MODE button accidently popped out. I was able to replace it in position but now it no longer "click" on push.
    I was wondering whether you all think whether the lower three buttons (- + MODE) can be repaired/replaced. I would hate to have to replaced the entire instrument cluster. If I do decide to replace the cluster, is it plug-and-play or do I have to find someone to code it for me?
    Thanks for any advice that you all can give.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    why did you remove the instrument cluster? radio install is very easy with the correct tools (enfig)
    Mar 10 2016
    I wanted to mount the GPS antenna behind he cluster but the left trim was over the housing and dislodged the Mode button by mistake. The GPS in the shark fin doesn't work in my car. BTW, was there at Enfig and Christian confirmed that it doesn't work.
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    If your GPS antenna has a magnetic back, then if you remove the lower panel under your steering column, there are metal support braces that provide a simple location that will get you good signal. That's where I put mine for my Pioneer AppRadio3.
    As for the instrument cluster buttons.... I have no experience with them unfortunately, but I'd bet your looking at a replacement, which will mean reprogramming for your keys as well.
    Next time you have a project, reach out to the community first for suggestions, links, etc. and use the search feature. Some members have TONS of experience with this generation of A4 and can help you avoid situations like this one. That's why we're here, to help & learn.
    Hopefully, someone will be able to chime in and provide you with a fix.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by denisavu View Post
    Guarantee you there is someone who can just solder a new switch on to that circuit board. I found a guy to solder new LCD's on to a couple instrument clusters I had on two B5's. I just put an ad in Craigs List. Got several response. Nothing special about the switch behind that Mode button.
    No, not even close. You'll trigger the immobilzer thing and your car won't start. If you really have to have a new cluster, I've got one I could sell you. But you'd have to send it to Tom at Speedometer Solutions along with your old one so he could clone it. Or you could take it to the dealer and give him your first born male child.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Mar 10 2016
    The switch has a plastic rod from behind that probably serves to depress a position on the motherboard. Can't see why that rod can't be fixed?
    Feb 24 2004
    Minneapolis
    So it's not the switch that's broken, its the plastic rod on the back of the Mode button? Somebody somewhere is selling a dead cluster.....you could just harvest the Mode plastic from one of those.
    Mar 10 2016
    Update: my Indy Audi guy was able to replace the switch on my original cluster. So all is good. Thanks to all who have responded.
