Results 1 to 30 of 30
    Stage 2 Banner Advertiser Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Help! Rear diff fluid change gone wrong. Side of road now!
    Just changed the fluid in the Sports Diff. Drained through this hole.
    Filled through this hole.
    Got less than a quart to go in. The tube I used to fill was a tight fit in the fill hole and about a quart in oil started coming out the top and dripping down from somewhere.
    I took the tube out and there was a lot of oil leaking. I let it drain it down til it stopped coming out the fill hole and plugged it up. About 10 miles down the road I'm getting a low whiney grindy noise coming from the rear...what did I do?
    Sent from my VS986 using Tapatalk
    AKA: jbullin2
    Dec 21 2014
    Milwaukee
    Fresh fluid appears to be leaking out from the top still. I'm under it now. What could have blown seal as a result of me overfilling and/or pressurizing the Sports Diff?
    AKA: jbullin2
    Jan 24 2014
    United States
    Sounds like you drained the fluid and tried putting fluid in the wrong hole.... I hope you havent got the same problems with women...
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    ouch!
    sounds like its gonna be an expensive repair, if the diff is broken.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Your pictures are little hard to figure out. Is it possible you drained the diff, but tried to fill the ATF fluid? Both are in that area (stupid way to do it....).
    Edit: I can't really tell what you are pointing out in the second/fill picture.....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    What fluid did you use? Weight?
    Also, what sound was it making when you turn?
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    You took a punt on servicing the second most expensive component of the car? Yikes...
    Call a tow truck and bring it to an indie or the dealer. Do not attempt another DIY on the side of the road.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Sounds like you need a rear diff. Sounds like the gears ate themselves up. Did you look to see how much fluid the diff takes? If you couldn't put that amount in give or take a little bit some bells should of went off in your head like something is not right here. Did you look up the manual on what exactly was the fill hole?
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Ouch! Good luck!
    2021 Audi S4, P34 Intake
    Aug 08 2008
    2017 Q5
    Houston, TX
    hopefully it isn't as bad as we are all thinking. good luck with it. let us know what goes down. get the flatbed out there though!
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I'm trying to orient myself from your pictures..
    Edit: I believe you drained from the passenger-side drain plug (diff oil) and filled the driver-side fill hole (smart-diff ATF fluid). So it appears you drained the Diff oil and topped off the ATF smart-diff fluid with the wrong oil type.
    Are you still under warranty??? I think you could play this right to get it covered.. You could half-way fill the diff with fluid and have it flat bedded to Audi. When they say you need a new diff you could blame the leaky seal which caused the diff oil to leak out. This is a known problem for early S4's. Of course if you do that you're a turrible person.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Feb 20 2006
    NC
    definitely appears you filled the wrong hole. Should have been pretty obvious as what you drained and filled are different (gear oil vs ATF). Expensive mistake.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Jan 14 2009
    pasadena md
    Looks like you roasted your diff. According to this write up and your pics you drained the gear oil and you tried to fill through the ATF hole. No Bueno. You might be able to save it but your probably done. You can fill the diff up and then your going to have to flush out the ATF circuit. to get whatever gear oil got in there out. Or you will ruin the clutch plates. My guess is that the diff is roasted.
    Jul 16 2012
    Mid-Atlantic
    I wonder if the car that Danger is parting out has an extra sport diff for you?
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Whops, saving $500 turned into spending $5,000
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    op read this, dont drive that car anymore till you get the fluids changed out and filled.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Gotta agree with everybody else...your diff was empty and grinding. Good chance the gears are completely ripped up already.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Even if there was minimal fluid left after draining, the gears and clutches still had some protection. As long as you pulled over AS SOON AS YOU HEARD THE GRINDING, you have a chance of saving it. You're going to have to flush both fluids thourghly, then refill and test. Or take it in as is and play stupid if you have warranty. Good luck
    Will
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    It sound like you definitely filled the wrong hole. I'm a little perplexed on it potentially being the trans fill but I've never got under there and checked myself.
    Diffs are never fully filled with oil AFAIK, only about 1/3 to 1/2 is typically submerged while at rest. so if you got overfill leakage, that would be a do not drive right there. If you manage to add to the trans, it's a guess on what might happen, depending on how much.
    My 2c is bring it to the dealership or a good indy that knows Audis or similar DSG/DCT/PDK cars and fess up and see what they recommend.
    There's a decent chance both the trans and diff will be ok but it depends on how far you drove it under how much load etc. Diffs themselves are pretty tough but the helical gears are very sensitive to wear pattern before they start to make noise. It might be ok with a slight whine once you put the right gear oil back in.
    Good luck.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Jan 14 2009
    pasadena md
    Quote Originally Posted by BoostEasy View Post
    Good luck.
    The rear diff uses ATF fluid to control the clutches in it. Also you fry the pinion and carrier bearings first before you damage the rin and pinion. The Pinion is the first to go. My guess is he damaged its lifespan and might be able to put fluid in it and get it to go again but longevity it out of the question. But I would fill it up clean it off maybe blow some dust on it and if you have warranty and take and in and be like there is a noise in the diff I don't know what happened.
    Nov 13 2014
    Manchester, England
    Quote Originally Posted by chaos2984 View Post
    If you're going that route, put the old gear oil back in. Fresh oil is a dead giveaway.
    Jan 24 2014
    United States
    kinda makes me glad I have the non-sports diff
    Aug 25 2013
    florida
    Quote Originally Posted by LaCross View Post
    we can't post stuff like that here, we will get banned
    good luck OP on your repairs!
    2014 sfeux p+ 6mt bo nav w/o sd
    Apr 27 2014
    United States
    Why's that? You still have to change the fluid....
    435I 6MT - Daily
    Jan 24 2014
    United States
    Yea but it's cake to change and cheap to replace
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    You put it in the wrong hole. Only problem is this time YOU'RE the one upset.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by Pared View Post
    Lmfaoo. Cried when I read this
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    What mileage is a good heads up to change the rear diff fluid? Even if you don't have the rear sport diff? I looked at the Audi interval service chart and it only shows info for the RS5. So i assume they are giving this one a lifetime guarantee as well" Rolls eyes"
    If they are "saying" lifetime i assume 85-100k would be a nice number if you planned to keep the car past 100k.
    Established Member Two Rings S4Drew's Avatar
    Nov 14 2015
    Ft. Worth, TX
    I am cringing for you OP.. I hope it's not as bad as everyone thinks.
    Current;
    2020 GMC Sierra
    Previous;
    2011 B8 S4
    1968 Camaro SS
    2006 Mazda6 5MT
    1994 Buick Skylark
    2002 Mercury Cougar 5MT
    1985 Audi 5000S Turbo
