Results 1 to 13 of 13
Thread: Something new
    Established Member Two Rings jesse_gabriel's Avatar
    Dec 09 2015
    california
    Something new
    I have a 2002 b6 and I want somewhere along the lines of 400hp. I would love to go with a v8 from the s4 or possibly even the rs4, if that is too crazy of an idea I can just have the 1.8 built. Any opinions?
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    You can make 400hp from a 1.8t without too much trouble. V8's make an awesome sound and with the JHM supercharger you're well over 500hp, but be prepared to accept poor fuel consumption. I'm not sure what a high hp 1.8t does for fuel consumption but I'd bet it's better than the S4 motor. Then consider the work of a transplant vs adding a big turbo and parts.
    Veteran Member Three Rings Gooner1886's Avatar
    Jul 20 2009
    Indiana
    Sell B6 A4. Buy B6 S4. done.
    B6 A4 1.8T Quattro Unitronic Frankenturbo stage 2+
    AKA: MitchFalk10
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by Gooner1886 View Post
    ^What he said.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Sell B6 A4. Buy B7 RS4. Done
    in all reality, i think to make the power you want, your most reliable swap would be a 2.7 with mildly tuned k04's.
    with the 1.8, youre losing alot of reliability at 400hp. With the V8, the S4 doesnt give you 400hp, the RS4 gives you 450HP but thats at crank, translates to roughly 320 at the wheels when all is said and done.
    19' Glacier S4 Black Optics
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Whoever tells you to buy a B6 or B7 S4 is doing you a disservice.
    Audi Club Bay Area
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    Quote Originally Posted by Furly View Post
    ^this, slide yourself into an AMG.
    Ed
    why say lot word when few word do trick.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    400 wheel HP or 400 crank HP? Either way, thats a fairly lofty goal that will require extensive engine mods (and supporting braking a suspension upgrades to be useful). You would be better off reducing your power goals slightly, or starting with a better platform (S4/RS4) IMO.
    2019 SQ5 Prestige
    Dec 09 2015
    california
    I definitely do not want to buy another b6 platform because I have put a lot of work into my current one and I know all the usual wear and tear items and I don't want to go through that twice. If I have arround 6k for the engine alone what would you guys recommend doing to it? I have an idea but I am just curious what you guys think
    Nov 10 2015
    Sudbury, ON
    400hp out of an 1.8T your going to need Rods at minimum. Pistons would be a good idea.
    Would also Need turbo (BT), Intercooler, clutch, Diverter Valve(depending on setup) and most likely Hi-flow manifolds.
    for 400HP out of a 1.8T, going to cost you probably $6K + to do it properly.
    A GTRS eliminator is a good option, with near enough to 300HP (CHP), no internals need to be replaced with a conservative tune.
    I assure you, a GTRS'd 1.8T A4, will be a very quick car, as a Stage 1+ is quick around town.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Dec 19 2013
    The B6 and B7 S4 is simply one of audi's worst motors. It's not going to make over 300 wheel stock, it's prone to timing chain guide issues, cylinder scoring , and many other things. It's a ticking time bomb. Plus it's embarrassing when a BT 1.8T pulls on you in your V8 ;)
    To do a timing chain job on the 4.2 the motor must come out. Everything is in the back of the motor by the firewall so you can't do it without. Google It. It looks like the inside of a Swiss watch. It'll cost you as much as going big turbo on a 1.8T if you have a shop do the timing chain job. Id upgrade your turbo or sell your car and get a C63 AMG.
    Audi Club Bay Area
    Apr 03 2016
    Up North
    ^ This man speaks the gospel. BT 1.8t will easily get you what you want...
    Aug 26 2007
    Quote Originally Posted by jesse_gabriel View Post
    ive got roughly 10k in my BT setup along with supporting mods and i just have the bare minimun for 400whp. Even so, im kind of risking it with OEM pistons and non built head.
