Results 1 to 6 of 6
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    Rear Poly Diff Mount (ECS, Apikol) vs Rear Diff Insert (034)?
    Has anyone driven or gotten to ride in both types of cars?
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Aug 01 2014
    Ohio
    They're two different things, but can be used together. I have the ECS rear diff mount, pretty solid. Want to get the inserts here soon, should tighten things up even more.
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    Quote Originally Posted by cg91 View Post
    You can only use the 034 inserts on the stock mount.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by derrek View Post
    Actually, you can use both of these upgrades together!
    The Apikol/ECS differential mounts replace the factory mount at the front of the differential. Our B7 Audi A4 Rear Differential Carrier Inserts install into the rubber bushings in the rear differential carrier / crossmember, behind the diff.
    Hope that helps!
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by 034Motorsport View Post
    Hope that helps!
    ahh!!! Thanks for the clarification!!!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by jerseybrian View Post
    Happy to help! All the mounts on these cars can get a bit confusing.
