Results 1 to 6 of 6
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    New Mod idea and question - OEM Style switches or clean looking switches.
    I'd like to add various switches for my upcoming mod plans (Subwoofer, auxiliary back up lights, and bi-xenon fog retrofit ) but want something with an OEM look. The best idea I have so far is to use the ashtray (who would smoke [cigarettes] in such a beautiful car?)
    With that said, the panel has to fit in that area. I have no qualms about cutting up the area under the door to fit a nice panel, so the max dimensions are something around 150mm X 40 - 50mm. Many of the marine rocker switches with lit up faces are just about too big to fit and they look 'almost' good/cool enough:
    The best thing would be a panel of OE switches from another car (possibly a VW or older Audi) that lit up and had the soft touch rubberized surface. If I could source a set of buttons that I like, making a panel to hold them out of ABS or even carbon wouldn't be too hard. But my real issue is finding switches that will look good, and also not break the bank.
    I've searched the Internets and only found answers in the Tundra and Jeep forums. Throw out ideas... I'm hoping to get a VAG-sourced answer (<---- someone knock that outta the park, I'm ready for comedy)
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    Quote Originally Posted by cal3thousand View Post
    How many switches are you trying to fit in there, 3 for the three things you listed?
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Feb 19 2013
    Quote Originally Posted by se.farrell View Post
    I'm thinking Left aux light, Right aux light, Sub On/Off, and Fogs blinding mode. So 4. Maybe an aux port too?
    I'm starting to think something simple like rubber booted marine style switches would be best, but don't have much cool factor. I found some that are so cheap, I might as well just fab something up real quick until I get more inspiration.
    Amazon 5 switches
    Or these are a little more heavy duty, but nothing is going to be carrying real current. I'll use a relay for the fog cut off shield activation:
    Heavy Duty
    But I'm still waiting on someone to show me something cool. Maybe I should go peruse VWVortex
    Dead:
    Jan 10 2014
    Los Angeles, CA
    I cant tell how wide each are, but you could use something like these;
    http://www.amazon.com/HOTSYSTEM-Rock...+toggle+switch
    http://www.amazon.com/HOTSYSTEM-Rock...YZNGHPRFHK8BFA
    Current:
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Feb 19 2013
    Those would likely fit 5 with room. I'll put them on the list of potentials. I'm starting to lean towards aluminum toggles.
    I'll post back when I have something more solid.
    Sent from my SM-N910T using Tapatalk
    Dead:
    Feb 19 2013
    I think I may have found my switches or at least the vendor to use. They seem to have a vast selection of switch-making parts and can customize my order. I think I will go with black faced buttons, 16 - 20 mm diameter buttons (should fit 5 easily with room for a USB and an Aux-in tap). They will also customize the engraving. Unless I find another option in the next week or so, I will go with this place:
    http://www.aliexpress.com/item/ELEWI...00014.6.i2hFm4
    Dead:
