Results 1 to 23 of 23
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    Currently under car looking for coolant leak
    As the title says I'm under the car right now looking for a leak.. seems to be coming from the front, and more driver side than passenger... and I can't see anything. There was a couple drops on the coolant pipe that runs next to the oil pan, but no trail to follow. It's a sizeable leak.. what could I be missing here
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
    Mar 24 2013
    Oakdale, CT
    Turbo lines would be a good place to start. Beyond that, possibly a leaking water pump or thermostat. Don't rule out the coolant flange since it can drip down and run along other parts before hitting the ground.
    -Adam
    Dec 08 2013
    Buffalo, NY
    That's the flange, looks pretty good there. T stat should have a leak right under the alternator more or less right? Like I can't even find a trail of dried coolant hah.
    Where would the water pump and turbo lines leak to? I'm a very novice mechanic hahah.
    Dec 08 2013
    Buffalo, NY
    Turbo lines right? Looks pretty clean
    May 20 2010
    What about the oil filter housing and stand (not the part with the actual filter, but the entire casing). I had a leak there, and I swear I could see the red of coolant. Of course, I also found oil everywhere.
    Feb 08 2012
    Dallas, GA
    Really dumb suggestion--did you just add coolant? The first time I added coolant, I spilled it into the ring around the filler neck of the overflow bottle. Apparently, that drains straight out the bottom of the overflow bottle. I thought I was leaking coolant from a crack in the bottle until I realized what I did. Sorry, I'm pretty novice too, so I apologize if I didn't describe something right or call it by the correct name.
    Dec 08 2013
    Buffalo, NY
    While looking, I caught a drip on the forehead. And found a track.. what am I looking at here?
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by KingWulfgar View Post
    Hahah I've been adding it every other week or so, to keep the level proper. But never over filled or missed so definitely not that haha, I appreciate the input though!
    Dec 08 2013
    Buffalo, NY
    From the top, also see a leak here. I believe this is going into the t stat correct? I'm thinking this is running down to where I see the leak below.
    May 20 2010
    Yeah, that's the vicinity of the thermostat. So maybe that is your culprit. Should be a DIY/sticky on here to do that.
    Has it ever been changed? How many miles? I think mine went between 120k and 130k.
    Dec 08 2013
    Buffalo, NY
    Changed it out around 120k because it was stuck open, about 2 years ago exactly. I don't remember the brand though, I got it from rock auto. I've a feeling the o ring went and not the t stat itself.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by 2pointOh View Post
    That's my gut, it's that O ring. But by the time you get to that O ring, your two easy bolts from swapping the stat. Might as well just do it.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by mtroxel View Post
    Ah yeah I'd definitely just swap it out. Only like $30 anyway
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    What did I tell ya man. Done deal
    2008 A4 S-line 2.0T
    JHM Stage 2
    Mar 24 2013
    Oakdale, CT
    20mmx3mm o-ring for that coolant pipe.
    -Adam
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by Schweini View Post
    Finally.. hahah took me an hour of laying there looking for something.. anything..
    So you're saying just do the o ring not the whole t stat swap?
    Mar 24 2013
    Oakdale, CT
    That o-ring doesn't come with a new thermostat. At least it didn't with mine. You will need to buy one whether you replace the tstat or not. If you have replaced it recently, I wouldn't mess with it. It's not like it's THAT hard to get to.
    -Adam
    Dec 08 2013
    Buffalo, NY
    Ah I see. Yeah I mean it's still functioning properly besides the leak. I guess worst case I find out once I'm in there that I need a t stat and grab one from the dealer.
    Thanks everyone for the help!
    May 20 2010
    When you do replace it, clean it REALLY well. Same case as with the rear coolant flange--if you don't clean it really well, it'll lodge on some debris or not sit perfect, and you end up with that all over again.
    Dec 08 2013
    Buffalo, NY
    The leaking pipe you mean? That's a good idea
    Dec 08 2013
    Buffalo, NY
    Where can I buy one of these o rings locally, dealer only?
    Feb 24 2004
    Minneapolis
    That's where I got mine. It was only $4.50...cheapest trip to the dealer in a long time.
    Dec 08 2013
    Buffalo, NY
