Results 1 to 8 of 8
    Senior Member Two Rings A4SlineWA's Avatar
    Aug 05 2015
    WA
    Is there something wrong with my suspension?
    Hi All,
    I have an 2011 S4 w/ADS and I put on some H&R Sport Springs. The car has 66K miles and I've had the springs on for 6K miles. I'm noticing sounds when I slowly go over a speed bump or when I rotate my wheel more than 90 degrees.
    The sound is nothing pronounced, more like, hard to describe. LOL It sounds like maybe something "might" be loose; light thudding sound. Normal driving or fast acceleration and stops don't produce this sound. Has anyone experienced this? Please share your insight.
    -RS4 Piano black grill -Stvbek Carbon Fiber Lip -19x10 Niche Targa wheels in Anthracite -20% -LED foglight and tail plate conversion -Inverted black/red supercharged badges -Interior LED lights -Solo Motorsports Stage II tune: APR pulley, belt w/ MAP programmer -93 OCT tune and Stock tune -APR Stage I + II Carbino Intake system -H&R Sport Springs -AWE Tuning Touring Exhaust
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    improper torque on the top strut nuts?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Pretty sure I am hearing the same noise. Is the sound you are describing like a subtle hollow sound? My car does this only at very low speeds (< 10mph) but my sounds comes from the rear. To me is sounds like my spare tire is loose. I am lowered on CO's but my car did this stock as well. I mentioned this to the guy who does my suspension work and he went over everything recently when he installed my sway bars and end links and said everything looked fine. I have friend with a B8.5 that is on the stock suspension and he says he hears the same noise.
    2016 S6
    Aug 05 2015
    WA
    I'm trying really hard to remember if I heard this sound when I first did the springs? I'm just worried, that I'll be driving one day and something comes off and I die.
    Aug 05 2015
    WA
    Quote Originally Posted by AudBoost View Post
    Pretty sure I am hearing the same noise. Is the sound you are describing like a subtle hollow sound? My car does this only at low speeds but my sounds comes from the rear. To me is sounds like my spare tire is loose. I am lowered on CO's but my car did this stock as well. I mentioned this to the guy who does my suspension work and he went over everything recently when he installed my sway bars and end links and said everything looked fine. I have friend with a B8.5 that is on the stock suspension and he says he hears the same noise.
    I believe I hear it more towards the front. I'll try and listen a little better. But if I were to compare the sound to something, it would be like the spare tire moving around because I didn't screw the fastener tight enough.
    Apr 05 2005
    Tampa, FL
    2016 S6
    Oct 31 2013
    Morris County, NJ
    Just put on H&R OE here as well, no noise at all, pretty silent. Sounds like something is loose.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by A4SlineWA View Post
    Lololol, let's skip right to the ultimate worst case disaster. Haha.
    2021 Audi S4, P34 Intake
