Hello Fellow ziners,
I currently own a s3 and helping a marine buddy selling his car. The car has been maintained by GMG racing ever since the owner moved to orange county so to say the least, it is in great condition and mechanically sound. Before anyone asks, the timing chain tensioners were taken care of at the time of purchase and never had an issue since then, Also the car has always been babied, never raced never modified and never molested what so ever.
2005
6 speed manual
170k Miles
Service history : -
10-Feb-11 96004 Les Schwab Tires Federal
14-Feb-11 96113 Oil Can Henry's Oil Change Full Synthetic
15-Feb-11 96412 VEHICLE PURCHASE
18-Feb-11 97195 Matrix Integrated Ignition Coil Volkswagen Gruppe, 077 905 115 T
18-Feb-11 97195 Matrix Integrated Wiper Blades Aero
2-Mar-11 98885 Matrix Integrated 95K Service
Repair LF pwr window
New glove box door
16-Mar-11 99890 Matrix Integrated Oil Change Total/Elf Quartz Energy 9000
Window shade clip RR
Tie rod bolts
Trailing control arm RF
Trailing control arm w/ ball joint RF
17-Mar-11 99938 Tommy's Window Tinting Window tint #20 blk
5-May-11 102915 Matrix Integrated Trailing control arm RF
18-May-11 103956 Matrix Integrated Valve cover gaskets R&R gaskets/seals
Cam adjuster solenoid seals
Cleaned throttle body
23-Jun-11 105465 Matrix Integrated Oil Change Total/Elf Quartz Energy 9000
13-Jul-11 106882 Matrix Integrated FL Trailing & Control arms
26-Sep-11 112152 Matrix Integrated Oil Change Total/Elf Quartz Energy 9000
5-Oct-11 112721 Matrix Integrated New FR/RR brake pads & rotors
9-Jan-12 118213 Matrix Integrated New tires, mount, balance Continental Extreme DWS 225/40/YR18
4wheel Alignment
26-Mar-12 121532 Les Schwab New front tires Continental Extreme DWS 225/40/YR18
5-Sep-12 124172 Matrix Integrated Oil Change Total/Elf Quartz Energy 9000
2-Jan-13 128007 Matrix Integrated New battery Interstate Megatron Plus
19-Feb-13 128945 Matrix Integrated Oil Change Total/Elf Quartz Energy 9000
1-Mar-13 129159 Matrix Integrated PS return line & cooler pipe
8-May-13 130915 Matrix Integrated Oil Change Total/Elf Quartz Energy 9000
1-Jul-13 133840 Pure Motorsport A/C Evacuate and Recharge
20-Jun-14 149092 Newport Auto Center Oil Change Castrol Synthetic 5W40
Replaced Ingition Coils (all) Ignition Coils
4-Aug-14 151010 Costa Mesa Smog Test Emissions Check
4-Sep-14 152199 Global Motorsports Group Flywheel & clutch replacement
Flywheel bolt
Flywheel
Clutch Kit (SACHS)
Pressure plate screws
Crankshaft seal, rear
Clutch Slave
Clutch line
17-Feb-15 156589 Global Motorsports Group Oil Change Labor
Oil Filter Kit (E355H01D109)
5W30 Mobil 1 synthetic
Wurth Drain Seal
Tires Hankook Ventus V12 Evo 2 (225/40ZR18)
Alignment Labor
Other Hood Shock
RF upper control arm bushings (broken/replace) Labor
Control Arm Link Bushing
24-Mar-15 157396 Global Motorsports Group Brake Light Switch Labor
Trunk Latch Motor Labor
17-Nov-15 164290 Global Motorsports Group Oil Change Labor
Mobil 5W30
Drain seal
Fuel filter Labor
Front brakes Pads
Discs
Rear brakes Pads
Discs
15-Dec-15 167514 Global Motorsports Group Passenger visor clip Labor
Cap
Hook
RR sunshade clip Labor
Bracket
Oil pressue light Labor
Oil level sensor
Mobil 5W30
Drail seal
Right mirror motor Labor
Mirror adjustor
MIL light (thermostat) Labor
Housing
O-ring
coolant
Distilled water
22-Feb-16 169962 Global Motorsports Group Tempurature Switch Labor
Switch
Coolant
25-Mar-16 169970 Smog Test Emissions Check
The price is right and you guys are welcome to come check it out.
Feel free to PM me or text @503-680-8874
List Date: 4/14/2016
For more info, click here to view the original listing: Clean B6 2005 s4 ( 6 speed ) for sale in SOCAL/Orange County - Never modified
This item is no longer available.
