I have a 2007 S4 6mt, I haven't owned it very long, but the other day I went out to a deserted road and did a couple pulls, not launching, probably 10-100. After the second one it felt like the engine was misfiring, but I didn't get any check engine lights or anything. I turned the car off and turned it back on and the roughness went away, which I thought was weird. I tried to duplicate the problem, and It came back, not every pull, but usually after two of them. It always goes away by restarting the car, I wasn't letting the car sit between turning it off and turning it back on, I cycled the ignition without hardly a pause. The car is completely stock.
I have decided that since I don't know how long its been since it has had preventative maintenance performed on it, that I would at least check the plugs, and they didn't look terrible, but I did discover a leaking valve cover, which I will replace along with the plugs for good measure. I will also order a fuel filter and air filter and a serp belt at the same time. I was reading about punching the primary cats, I might do that too, but I would rather chase the problem on a factory car, unless there is a chance something could have gone wrong with the cats to be causing this?
Does anyone have an idea what could be causing the (I don't want to call it a misfire because its not throwing a code) "rough running" after high load, high rpm operation? Is there anything else I should replace while I am in there?
Thanks
