Results 1 to 4 of 4
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    UPDATE... Dyno chart from last week's runs...
    We dynoed on a pretty shitty day weather wise. There was a low pressure over the area and it was raining hard with fog so very high humidity, two factors that do not help at all for dynoing a car. The dyno room was in the high 60s low 70s temperature wise. Perhaps with a more normal barometric pressure and less humidity the numbers could have been higher but that's a debate for another day.
    The only difference mechanical wise to the car is that for this dyno we were tuning with the Integrated Engineering's intake manifold so I have to assume the difference in numbers is because of this intake.
    This is the 24.5 PSI run. We did not tune for a higher PSI on this day, perhaps later this summer. I am hoping for a 30 PSI map at one point.
    The solid lines represent this year's dyno tuning with IE intake. As can be seen both HP and Torque lines are ahead of last year's run up to about 4750 RPM. From 4750 to about 6200 RPM there is a dip in both HP and Torque figures compared to last year's run. Above 6200 RPM both of this year's HP and Torque figures regain higher numbers.
    In the end peak Torque this year is down 12 ft/lb to 352 ft/lb but peak HP is up by 19 HP to 455 WHP.
    Can't wait to take out the car on the track!
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    What's your specs?
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Glad to see you're still at it Jet. As always, very impressive. When are you back on the track? Need some more of that in-car vidya.
    Veteran Member Four Rings MMMB00ST_A4's Avatar
    Mar 31 2009
    NC
    Quote Originally Posted by aysix View Post
    What's your specs?
    You want ALL of Jockey's specs? Be careful what you ask for...lol
    -Brandon
    APR | Oettinger | KW | iForged | Evolution Racewerks | Labree | Carbinio
    12.9@104mph
