Results 1 to 11 of 11
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Lets play a game of... how old is that timing belt.
    Alright guys so as the title suggests i don't know when my timing belt was replaced as the PO left me without a single receipt. Everything i have seen on the car was oem parts so thankfully it seems to be dealer maintained. Anyways cutting to the chase here i wanted to see if you guys could guess how old this belt is. interval according to the manual is 105k and the car has 146k
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    It is really hard to tell age and mileage from a belt just by looking at it. So, I don't think anyone can tell you this with certainty. Perhaps someone who knows what original OEM belt from 2002 looks like can chime in and say that a version with logos you have was produced from 20xx and that gives you an idea.
    My Gates Racing belt that has only 40k on it looks horrible (tiny cracks) and I will be changing it. Your belt certainly does not look 14 years and 146k old, so I'd say it has been changed at some point. But that's a $4000 guess from a guy on the internet. You can also removed the cover completely, grab an inspection mirror and check the bolts on the water pump, crankshaft pulley etc. for signs that they have been removed/replaced. You would see obvious signs like sockets scratching the area. That should tell you that work has been done.
    What I'd do is go to your friendly neighbourhood Audi dealer and ask nicely whether they can search your VIN and tell either printout a copy of the history they have (they will likely not do this due to privacy issues), or write down all the major service performed (too much work for them) or simply tell you whether timing belt service has been done.
    Hope this helps a bit.
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    That actually looks pretty dang new. It doesn't take long to wear the printing off of a timing belt. If I had to make a guess, I'd say it has less that 15k on it. I'll tell you that mine was done about 65k miles ago (according to the PO) and it looks like total crap. It's discolored to a brownish hue and there's absolutely no printing left on it. I'm changing it out this weekend.
    Aug 17 2015
    Evansville, IN
    Not mine, but this is approximately what mine looks like at "65,000" miles. The PO was full of shit about a lot of things, so take that figure with a grain of salt.
    Aug 27 2013
    Philly
    Goldern Rule of timing belts: Unless you have documentation of when it was last changed, CHANGE IT ASAP.
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    ^ This. If you don't know, CHANGE IT!!! $2-300 in parts now will save you a hell of a headache
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    Quote Originally Posted by SJorge3442 View Post
    I concur. better safe than sorry when in question of a timing belt.
    Jun 21 2015
    LI, NY
    thanks for the input guys, yeah i did plan on changing it soon. Now that i have taken a look and it doesnt seem to bad im not sure that i will do it before i try to get documentation from the dealer. my "guess" would be that it was replaced right on interval at 105k.
    01.5 B5 S4 6MT SOLD
    Oct 02 2006
    Wadsworth,OH
    I wouldn't wait if I were you. Belts can be deceiving... The back may look good but all it takes is a couple teeth on the belt to let go and good bye valves. And that's if it lets go at low rpm and you get lucky and not have the head of the valve/s break off and it destroys pistons and cylinder walls...
    Jason
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Carfax has a service called MyCarfax. Once you sign up, you can add a car to your garage then you should be able to see the past service records for the car.
    I've been using it for some time, but I seem to remember that you did have to go through a certification step to prove the car is yours.
    There's an Android app and a standard web browser front end. Probably iOS as well.
    Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    It's nearly impossible to tell the age of a timing belt apart from excessive wear due to other issues (not the age of the belt). A belt can look fine and then snap in the next 100 miles. If you have no service history from the previous owner, the safest solution is to go ahead and get the timing belt service done now and reset the service interval clock from there.
    The typical recommended service interval for timing belts (as discussed in older threads here) has been:
    60k - 70k miles for the 1.8T engine
    80 - 90k miles for the 3.0 engine
    Audi factory originally had belt replacement done every 105k - 115k miles regardless of engine, but I think it was reduced to 75k for the 1.8T (not sure for the 3.0).
    Yeah, you're paying now, but you'll have piece of mind knowing that it's been addressed and good to go for a long time.
    USP CLUB MEMBER #34
