Results 1 to 13 of 13
    Nov 18 2013
    Lynnwood
    SSAC / XSPOWER downpipe clamps?
    Hey guys, so I decided to give these SSAC / XSPOWER downpipes a shot. The fitment was not too bad, but I have an exhaust leak where the midpipe (not sure if this is the name) is flared to slip over the downpipe (not sure the name). I tried cranking down on the provided with a 1/2" breaker even and the midpipe is still slipping on the downpipe. Any suggestions for better clamps without having to remove anything and reweld?
    Thanks.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    just go get a muffler shop to weld them up for you...
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Nov 18 2013
    Lynnwood
    Can they weld them in the car? How much did it cost you?
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    i paid less than $450, but that was also building/installing my true dual/race catback listed in my sig... gets comps everyday from her sound
    PAST
    Current
    Nov 18 2013
    Lynnwood
    Hmmm not really wanting to pay very much... Welding is probably a last resort, I imagine they would want a few hundred at least and that's the price of the downpipes lol..
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    If they provided standard crush type clamps try using a band clamp instead.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    you could try AccuSeal clamps , they seem to seal pretty good (look them up on google)
    Nov 18 2013
    Lynnwood
    The clamps they provided look almost identical to those accuseal ones, I wonder if the accuseal type would make a difference
    Nov 18 2013
    Lynnwood
    I ordered some exhaust sealant goop but the clamps dont even tighten down so the downpipe will bounce in and out of the mid pipe... has anyone used some kind of wrap for a shim? Aluminum foil?
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    you need an exhaust pipe expander , or a visit to a muffler shop
    Nov 18 2013
    Lynnwood
    Going to try and wrap a layer of this around the inner pipe: http://www.amazon.com/DEI-010408-1-5..._detailpages00
    and tighten down... last resort, muffler shop.
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    I would say $100 max to get them welded. Go to a mom and pop shop and tell them what you want. You would be surprised how cheap it could be.
    Nov 18 2013
    Lynnwood
    Ok, thanks. They would have to remove the exhaust to get at these though, and probably remove the downpipes to get the weld all around, I imagine it would cost way more.
