Results 1 to 40 of 46
    Senior Member Three Rings musasabi's Avatar
    Aug 11 2014
    Chicago, IL
    Misfires. Swapped coils and plugs. More misfires.
    While I was in Michigan for a funeral, the RS4 started acting up. I had observed a slightly rough idle and a CEL every now and again for a couple of weeks, but nothing that was overly concerning. However, on March 19th, shit got real. After a handful of short (<20 mile) drives throughout the day, I had the car off for two or three hours, then back on for a quick ~10 mile drive to get some pizza. 20 minutes later, pizza in hand, I got into the car and headed back to the hotel. However, after less than a minute of running time, I felt a truly rough idle and it got to the point where it was even rough under acceleration. Scared the shit out of me. The CEL started flashing and I babied it back to the hotel.
    I left the car off for four or five hours, and went to get this scan:
    Code:
    Address 01: Engine        Labels: 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560 J    HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     ª0010
       Revision: 57H26---    Serial number:
       Coding: 01040009180F0160
       Shop #: WSC 44320 000 1048576
       VCID: 2D5A1034B4B86549F59-8078
    2 Faults Found:
    012424 - Starter Relay
                   P3088 - 001 - Electrical Malfunction - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 0
                        Fault Frequency: 83
                        Reset counter: 255
                        Mileage: 124246 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 9.0°C
                        Temperature: 17.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 11.049 V
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139275 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 44.0°C
                        Temperature: 39.0°C
                        Voltage: 11.303 V
    Readiness: 0000 0000
    Address 11: Engine II        Labels: 079-910-560-BNS2.lbl
    5 Faults Found:
    000768 - Random/Multiple Cylinder Misfire Detected
                   P0300 - 001 -  - MIL ON
                 Freeze Frame:
                        Fault Status: 11100001
                        Fault Priority: 0
                        Fault Frequency: 5
                        Reset counter: 255
                        Mileage: 137199 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1533 /min
                        Load: 46.3 %
                        Speed: 0.0 km/h
                        Temperature: -3.0°C
                        Temperature: 1.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.970 V
    000773 - Cylinder 5
                   P0305 - 001 - Misfire Detected - MIL ON
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 5
                        Reset counter: 255
                        Mileage: 137199 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1533 /min
                        Load: 46.3 %
                        Speed: 0.0 km/h
                        Temperature: -3.0°C
                        Temperature: 1.0°C
                        Voltage: 13.970 V
    000770 - Cylinder 2
                   P0302 - 001 - Misfire Detected - MIL ON
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139220 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 2775 /min
                        Load: 21.6 %
                        Speed: 54.0 km/h
                        Temperature: 48.0°C
                        Temperature: 30.0°C
                        Voltage: 13.716 V
    000771 - Cylinder 3
                   P0303 - 001 - Misfire Detected
                 Freeze Frame:
                        Fault Status: 01100001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139263 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1790 /min
                        Load: 20.4 %
                        Speed: 14.0 km/h
                        Temperature: 79.0°C
                        Temperature: 37.0°C
                        Voltage: 13.589 V
    000772 - Cylinder 4
                   P0304 - 001 - Misfire Detected
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139265 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 773 /min
                        Load: 22.3 %
                        Speed: 0.0 km/h
                        Temperature: 92.0°C
                        Temperature: 34.0°C
                        Voltage: 13.462 V
    I fired up the car a few hours later and the CEL was gone. The gently rough idle persisted, but CEL. On the 250 mile journey home, the CEL came back, but nothing nasty under throttle, nor any blinking CEL.
    Once home, I bought myself a new battery (it was pretty far gone anyway) and a new set of coils and plugs and dropped them in. The four plugs and coils closest to the firewall all had varying degrees of corrosion and gunk on them, but the front four looked cleanish. I have to assume that this is the first time they've been changed.
    I fired the car up... and it got worse. I decided to drive it around for a bit and noticed a whole slew of screwy behavior. Poor thing. When I'd get off the accelerator and start coasting when approaching a stop in neutral, it'd rev up to ~1,600rpm and hold there until either I slowed to under 5mph or until I pressed the clutch pedal down. And yes, there were many blinking CELs to be had on and off again for the ~5 miles I had it out.
    Finally this afternoon, I got around to scanning it again, and got this:
    Code:
       VCID: 2D5A1034B4B86556E5-8078
    3 Faults Found:
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 124246 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 15.0°C
                        Temperature: 21.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 11.557 V
    005634 - Power Supply Terminal 30
                   P1602 - 002 - Voltage too Low - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
                   P1923 - 008 -
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139876 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Temperature: 11.0°C
                        Temperature: 15.0°C
                        Voltage: 11.303 V
    Readiness: 0010 1100
    8 Faults Found:
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 137199 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 834 /min
                        Load: 18.8 %
                        Speed: 32.0 km/h
                        Temperature: 84.0°C
                        Temperature: 49.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.716 V
    000773 - Cylinder 5
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 137199 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 834 /min
                        Load: 18.8 %
                        Speed: 32.0 km/h
                        Temperature: 84.0°C
                        Temperature: 49.0°C
                        Voltage: 13.716 V
    000770 - Cylinder 2
                   P0302 - 001 - Misfire Detected - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 139220 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 2775 /min
                        Load: 21.6 %
                        Speed: 54.0 km/h
                        Temperature: 48.0°C
                        Temperature: 30.0°C
                        Voltage: 13.716 V
    000771 - Cylinder 3
                   P0303 - 001 - Misfire Detected - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139263 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1790 /min
                        Load: 20.4 %
                        Speed: 14.0 km/h
                        Temperature: 79.0°C
                        Temperature: 37.0°C
                        Voltage: 13.589 V
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Load: 0.0 %
                        Speed: 0.0 km/h
                        Voltage: 0.000 V
    000775 - Cylinder 7
                   P0307 - 001 - Misfire Detected - MIL ON
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139864 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 772 /min
                        Load: 16.9 %
                        Speed: 0.0 km/h
                        Temperature: 63.0°C
                        Temperature: 26.0°C
                        Voltage: 13.970 V
    000774 - Cylinder 6
                   P0306 - 001 - Misfire Detected - MIL ON
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139864 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 784 /min
                        Load: 15.7 %
                        Speed: 0.0 km/h
                        Temperature: 69.0°C
                        Temperature: 30.0°C
                        Voltage: 13.716 V
    000776 - Cylinder 8
                   P0308 - 001 - Misfire Detected - MIL ON
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 139864 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 803 /min
                        Load: 20.0 %
                        Speed: 0.0 km/h
                        Temperature: 74.0°C
                        Temperature: 33.0°C
                        Voltage: 13.716 V
    Oy...
    So, next steps for diagnosis? I did triple check again today that the coils and their connectors are snug, but other than that, I'm at a loss.
    2014 S4 | 6MT, Moonlight Blue, Black Optics, Sport Diff, Navi+, B&O
    2008 RS4 | Daytona Grey, Titanium, Exclusive
    2013 Jetta TDI | 6MT, Fender Audio, Sat Nav
    2003 Passat GLS | 5MT, APR 93 Tune, Koni FSD/Eibach Pro Kit, Magnaflow Muffler
    Established Member Two Rings mk420thae's Avatar
    Sep 22 2009
    Lexington
    More than likely a fuel injector.
    Sent from my SM-G900P using Tapatalk
    JHM tuned Avus Silver RS4
    Apr 07 2012
    Montreal Quebec
    I'm no expert but i did have a similar issue with the throttle hanging between shifts... It was the clutch module 60$ part
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by mk420thae View Post
    How one does test? I mean, I'll Google it, but if you've got a handy link or feel like typing a few lines... ;)
    May 06 2014
    2015 Ford Mustang Ecoboost, 2011 Nissan Armada SL, 2015 Buick LaCrosse E-assist
    Beloit, Wisconsin
    Did you ever get around to checking the long/short term fuel trims? Would help determining if it's a fueling issue.
    Sep 22 2009
    Lexington
    Swapping it like the coils.. But you have to remove the intake manifold.. So you may as well replace them. They are pretty common to fail. I had to replace one of my last month. Went ahead and did all 8
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by Al Sline View Post
    Huh. Interesting. If it didn't manifest 100% right now in correlation with the misfires, I'd follow that lead. Suffice it to say, I'll follow the lead if the throttle hang keeps on after I fix the misfires.
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by seishuku View Post
    Oh, nope. Forgot. Whoops. =D
    Ah, sure thing. Time to look up prices...
    Aug 11 2014
    Chicago, IL
    Ouch. $200 each.
    Well... That's on the list.
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    faulty ecu relay
    Sep 22 2009
    Lexington
    Quote Originally Posted by musasabi View Post
    Ouch. $200 each.
    You can find them cheaper. Can't remember the site but they were a little over $50 each. Made by Hitachi. Same company that makes the OEM ones
    Apr 07 2012
    Montreal Quebec
    Rock auto for the injectors 57$
    Aug 11 2014
    Chicago, IL
    This?
    Senior Member Two Rings SQ RS4's Avatar
    Feb 02 2015
    2008AudiRS4 2016AudiS6 2009NissanGTR 2016HondaPilot
    Clarksburg, MD
    Why not remove the original injectors and send them out to be flow tested, cleaned, and flow matched?
    Car would be down for a couple days, but it will say you some $, while allowing you to retain the original injectors.
    Check the following thread for more info:
    http://www.audizine.com/forum/showth...or-Maintenance
    Mar 11 2008
    B7RS4 & e46Ms
    based on the frequency, I'd say it's not the injectors, but something electrical (relays - I've been preaching this a lot lately). The frequency just doesn't fit injectors, nor does the fact you're seeing it across multiple cylinders. Maybe a HP fuel pump, but I'd guess electrical...
    FRRG AZ Ring
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Clearly it's the JHM tune.
    Apr 07 2012
    Montreal Quebec
    Weird the price really was 57 per injector!!! Your best bet is to get them cleaned and flow matched... I believe its less than 30$ a piece
    Established Member Two Rings S4Caster's Avatar
    Aug 19 2005
    Central NJ
    I noticed in your first scan it mentioned ECU 2. I recently had a short in ECU 2 and found a used one (thanks 65vettec6) as new is really pricy, and that fixed similar problems to what you described...misfires under acceleration, rough idling, blinking then steady CEL, etc. Not saying that's it, but worth noting. I actually had a remanufactured ECU 2 (X in the part number) that was in there, so there must have been previous problems in my car. Hopefully the original part number ECU will keep further problems from happening. Fingers crossed. GL.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by komseh View Post
    Well played.
    FRRG AZ Ring
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by S4Caster View Post
    Oh boy... Haha. If I go through coils, plugs, injectors, and a relay or two just to discover it's an ECU problem, summer is going to get pricey. >.<
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by SQ RS4 View Post
    Yeah, there's a place near me that'll do it for $20 a piece.
    Though it's a good thing I don't have the injectors out yet. I called the shop and the guy said there were 20 units in front of me. Somebody dropped off eight and someone else dropped of 12 that same day. Seems like we've got a DIY'er Lambo in the area, haha.
    Veteran Member Three Rings gesTTalt's Avatar
    Oct 10 2004
    The injector is listed under R8. I just bought 8 and will be installing this weekend
    http://www.rockauto.com/en/catalog/a...njector%2C6224
    07 Daytona Grey RS4
    Aug 11 2014
    Chicago, IL
    Sweet. Good luck to ya. =)
    Also, have any of you chaps bothered to replace the o-rings? Those look a snitch pricey, too.
    Oct 31 2005
    Ashburn
    O-rings/seals are pricey. However buying new injectors you will need them, In case someone does I have a full set still in the package. When I got my Injectors cleaned/flowed matched the shopped replaced all my seals with new ones for testing.
    - Instagram: @Sinister_rs5-
    Aug 11 2014
    Chicago, IL
    Ho ho, mightly kind of them. Since I'll be taking mine out to take to the shop, I doubt I'll get the same service. Probably won't cost me as much as yours did, though. =)
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    this is not injector related ,just changed your ecu relays .15$ and its fixte
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by Quattrors4 View Post
    Part number?
    Jun 18 2009
    Phoenix, AZ
    Those codes and that hanging idle to me point to something electrical, I agree with koolade. Have you had a look under your ECU yet to see if the relays are ok? Sometimes they can get corroded.
    2017 Camaro SS 1LE
    Oct 10 2004
    You can get just the o-ring, spacer, and teflon sleeve. 1/2 the cost of the brackets and clip set.
    https://www.ecstuning.com/ES2065056/...zHMRoC57zw_wcB
    07 Daytona Grey RS4
    Oct 11 2007
    Suburbia
    Quote Originally Posted by gesTTalt View Post
    Do you need to get these flow matched, or are they plug and play?
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Aug 11 2014
    Chicago, IL
    Quote Originally Posted by FWP! View Post
    I haven't, no. Did a quick search, but didn't see anything conclusive (driving a rare car is cool, ya know?) - are the relays actually _in_ the ECUs?
    Oh, score. 1/3 the price, even! Haha.
    Jun 25 2009
    SC
    The relays in question are under the ECU nearest the driver side, you need to remove the windshield wiper arms and cowl to get to all of the ECU housing t30 bolts. After that there are 3 relays, just plan on replacing them all while you're in there.
    Aug 11 2014
    Chicago, IL
    The relays are under the ECU, you need to remove the windshield wiper arms and cowl to get to all of the ECU housing t30 bolts. After that there are 3 relays, just plan on replacing them all while you're in there.
    Makes good sense. Thanks. =)
    Sep 20 2015
    Do you know the part number for the 3 relays? Are they 643 relays?
    Jun 25 2009
    SC
    Quote Originally Posted by simple_king View Post
    Two of them were 614 relays PN# 8E0951253. I replaced them with relays numbered 644. IMO this is a part you want to get from the Audi dealer.
    Sep 20 2015
    Thanks. Is the third relay the same or a different number?
    Jun 25 2009
    SC
    Don't remember anything about it except maybe it was smaller than the other two...
    Aug 11 2014
    Chicago, IL
    Well, I swapped in new relays today and checked the injector's fuel trim data. They're bad, but not out of spec. 5.1% and 9.0% on the two blocks I could find. And, I think I'd be seeing some sorts of lean codes if the injectors were really the problem, right?
    And, of course, the relays didn't fix a damn thing.
    I'm starting to worry this might be ECU2 freaking out on me. While looking at VCDS, I saw cylinders 5-8 racking up misfires like crazy, at a steady pace. Meanwhile, 1-4 weren't.
    Soo... anyone else have a slave ECU they want to sell?
    Jun 18 2009
    Phoenix, AZ
    5 and 9% is that short or long term? If that's long term, that means you have a lean injector (not spraying properly), or if that's short term, that means you have a vacuum leak.
    2017 Camaro SS 1LE
    May 06 2014
    Beloit, Wisconsin
    But causing misfires on only one bank?
    Seems unlikely to be injectors causing this... Might not be helping the engine, performance wise, but not total misfires on one whole bank of cylinders.
