So I thought I'd take a moment and share some data that I've been collecting as I upgraded my vehicle.
I've done a TON of datalogging and I've sifted through it all to give you all an idea of what you can expect to gain from different stages of hardware upgrades
Below, are 4 stages of upgrades. Unfortunately I haven't found any good data for a completely stock ECU and exhaust. However, I'd say that 250-255 AWHP is a reasonable estimate for a tiptronic S4 and it would be consistent with the 260-265 AWHP results that I have noted with the tune below.
A few things to note: First, the tuning between upgrades was changed. So that may account for some of the differences in the dyno plots.
Second, the upgraded exhaust was made from the catback portion (w RS4 resonators) of a used B7 RS4 exhaust that a buddy had given me. However, since the RS4 mufflers didn't fit, I used a set of Magnaflow ones.
As well, the RS4 exhaust is 2.5 OD, so the ID is something like 2.35 inches. I know that the common line is "blah blah blah, anything less than 2.5 in ID is choking off the car" I say BS, while a 2.5 in ID exhaust is preferable, I'd say that the results below indicate that a 2.35 ID or even a 2.25 ID exhaust will work just fine. The important part is putting in a balance pipe and getting rid of the damn cats.
Also, as you will note, I am also running a water/meth system. The reason being is that anyone who knows anything about tuning these cars will know that the S4 ECU is CRAZY knock sensitive. So being able to keep detonation at bay will make for some significant gains on this platform.
Finally, please note the yellow dyno line. This is what I observed when I installed my downpipes before changing the cam phasing (and before the H pipe). I started a thread on it here http://www.audizine.com/forum/showth...6#post11549426
But you can see the difference that simply retuning the cam phasing and manifold chageover made when you compare the yellow and grey dyno plots.
I cannot stress this enough, if you put a set of catless downpipes in and keep the stock exhaust, PUT IN AN H PIPE and retune the cam phasing!!!!!! These cross plane V8's need a balance pipe, otherwise they loose a bunch of low end torque. As well, you need to retune the cam phasing and manifold changeover.
Finally, you will note that the stock weight that I used was 2200 Kg, whereas the car gets progressively lighter as I do the exhaust upgrades. This is partly because the stock cats and mufflers are friggin' HEAVY. It is also due in part to the amount of fuel I had at the time and a bunch of tools that I removed from the trunk between dyno pulls.
So with no further ado........ here is is:
1) Stock exhaust with ECU tune (my own tune based partly on my old Fabspeed tune) *GREEN/BLUE
2) 2.5 in catless downpipes stock catback without an H pipe OR retune for cam phasing (aka "old cam phasing strategy") and manifold changeover *YELLOW
3) 2.5 in catless downpipes, stock catback without an H pipe but WITH retuned cam phasing and manifold changeover *GREY
4) 2.5 in catless downpipes, stock catback with H pipe and with retuned cam phasing/manifold changeover *RED
5) 2.5 in catless downpipes, RS4 catback piping, Magnaflow muffers, H pipe and water/meth (and my own ECU tune obviously) *ORANGE
Not too shabby if I say so myself
Peak differences between the stock exhaust system and the full exhaust + W/M set up are about 30 AWHP and 25 AWTq. Ill tell you, the car feels lightyears different than it did when it was stock.
As the dyno results indicate, I found that unless you make these changes, you will incur significant losses throughout much of the powerband.
