Results 1 to 35 of 35
    Established Member Two Rings ARoach04's Avatar
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    ECS flush kit on 19" Flowers
    Is anyone running the ECS Flush spacer kit on the 19" flowers? If so, have you had any issues getting the front rims to seat correctly on them?
    I'm working with Jason from ECS in another thread on why I can get mine to stop vibrating, was wondering if anyone has had luck with these given they're for the peelers.
    '16 Audi S4 Premium + | DSG | Florett Silver | Sport Differential | MMI+ | BO | Black Optics | ECS | V1 | AWE |
    '15 Audi Q5 Prestige TDI | Glacier White | MMI+ | BO | Black Optics |
    Nov 08 2015
    Newtown sq, Pennsylvania
    Went with 10mm up from instead of 8mm no problems. Since the 8mm has a smaller lip
    2016 Glacier White S4 P+
    6MT | Black/Magna Nappa Leather | Tech Package | Carbon Inlays | Sport Diff | Alu-Optics | Black Optics | B&O | LED Interior Lights |
    25% Tint | LED Fogs | 19" BBS CS5 Winter Setup | Eurocode sways F+B | Eurocode endlinks F+B | Deval Diffuser+Front Lip | | ECS 10mm Spacers | USP Stainless clutch line | E-codes | ECS Diff mounts | Eurcode Tranny mount |
    Senior Member Two Rings Seattle996's Avatar
    Apr 07 2009
    No problems at all. I grabbed sandpaper and cleaned the hub completely and then applied an anti seize greese. Drives like stock, took it to 90mph.. No vibration since, installed about a month or so ago.
    Sent from my SM-G928T using Tapatalk
    B9 SQ5... goodies incoming...
    F10 M5 6spd - Real Drivers Use 3 Pedels - BPM Tune - SOUL Exhaust - 21" AG M590 on MPS4S Tires
    FZJ80 Land Cruiser
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Quote Originally Posted by hyetiko View Post
    Humm, what do you mean by a smaller lip?
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by ARoach04 View Post
    The hubcentric lip that fits into the back of your oem wheel. It helps the wheel lock onto the spacer better.
    I have the flush kit on my peelers. Flowers or peelers shouldn't matter. You shouldn't be getting a vibration from them.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Mar 21 2015
    Go on ECS site and look at the difference from the 8 to 10
    Jun 30 2015
    Interesting.
    I had real bad shake upon initial assembly. Took everything off, had fronts balanced again, re-assembled and most of it went away. But at 68-72 it's pretty bad still. Under load it subsides a bit.
    This is BO 19" wheels and the flush kit 8mm spacers. Torqued evenly and in steps, hand snugged with extension to start. Never had problems like this on other cars with spacers. But glad to see I'm not the only one.
    I just thought I was being picky. lol
    Nov 20 2014
    New York
    I had the same issue with their kit. Ended up returning the front 8's by ECS and getting 10mm HR from them. I still had a slight vibration but I think it's because I didn't clean the surrounding areas and wheels very well. I kept the 12.5 in the rear but I should've just went with 15mm HR back there too
    Established Member Two Rings vwaddikt's Avatar
    Apr 08 2015
    15' S4 • 16' SRT Jeep • 01' Jetta 1.8T • 2002 Trans Am WS6 • Buell XB12R
    Eau Claire, WI
    Have the flush kit on mine... No issues whatsoever. Shouldn't be any fit difference between the flower/peelers with the spacers.
    Sent from my iPhone6 using Tapatalk
    2015 S4 | Nogaro Blue | Prestige | Black Optics | 6MT | Sport Dif | B&O
    IG: @komro
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    OP or anyone who has the BO 19" 5-spoke Flowers any before/after photos with ECS flush kit?
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Apr 11 2012
    do the spacers spin freely around the hub when installed? That's when you know you sanded down enough rust. Its also recommend to use two wheel hangers when installing the wheel.
    Jun 30 2015
    I changed 8's for 10's today and it's night and day.
    It's really a joke ECS is selling the 8's with the flush kit IMO. The fitment in the wheel goes from sloppy to snug between the two.
    If you're having issues, just bitch them out a little and maybe they'll make a change.
    If anyone wants some 8's I have some for sale lol
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by rota92 View Post
    ...Right.
    Or you can just give us a call and let us know you would like to exchange them for 10mm spacers if you're not happy. We've sold many of these kits and there has only been a couple people that seem to have issues.
    Depending on if you have lowered suspension or a wider fitting tire 10mm may be too much up front and cause you to rub. This is the reason we included an 8mm spacer so even if you are pretty low or have a wider tire you still have a nice flush fit but enough clearance not to rub.
    Unfortunately 8mm spacers do not have enough material to allow for a hub extension like a 10mm. There's only enough to add the chamfered lip - which will definitely help center the wheel better than a spacer that is flat.
    Jason
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    I recently ordered the flush kit from ECS 12.5mm rear, 8mm front, and after reading posts about potential vibration issues with the 8s up front (and having no plans to lower my car) I called customer service and worked with Rachel and she allowed me to send back the 8s, in exchange for the 10s, thanks ECS!
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
    Jun 30 2015
    ...Right.
    Jason
    I tried two channels to get to the bottom of things, granted I'm in an odd scenario as I took them off the hands of a friend but the people I spoke with seemed absolutely helpless even from a feedback aspect.
    The other thread has my trials and tribulations in them, I'm not just slinging mud. I totally understand the reason for the 8mm up front given the idiots that dump their cars and expect everything to work right. But this is the second time I've had an issue with your products and have received no help at all. But you've got us all by the balls with such an extensive selection of parts and timely order processing.
    Regardless of my personal beef, there are issues here with the 8mm spacer and vibration and it's not going away. Tribal knowledge through forums for an exchange really isn't a problem solving answer.
    Oct 02 2006
    Wadsworth,OH
    Sorry to hear how your situation was handled. Seems slightly out of character from expectations. But I will say typically warranty or support is not transferable with out proof of ownership. Usually if some evidence of owner ship is shown like a photo or two we can do our best to make something happen. That being said do you have an e-mail or phone number we could contact you at? Shoot me a PM with a best contact and I'll have our customer service supervisor give you a call.
    Jason
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    I'm having the same issue AFTER installing ECS' two piece rotors up front. Turns out there's not enough room on the hub with the new rotors + spacer. The cause of vibration is due to my wheel riding on the LUGS and not the hub ... VERY dangerous!
    Trying to work this out with Jeff @ ECS right now ...
    After taking off the 8mm spacer the car drives fine.
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by kcobourn View Post
    PM'd you back.
    Jason
    Aug 01 2015
    Edmonton, Alberta
    I have just installed HR OE springs and ECS spacers. 10 mm front and the 12.5 mm rear. I have the 19" flowers. No issues at all, except a slight vibration after 328 km/h....
    Car also looks MUCH better.
    The thread was helpful as I was originally going to order the flush kit.
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by repcapale View Post
    Pics?
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    Couple questions...
    1) What is the diff between 19" "peelers" and "flowers". I have the 19" OEM wheels, are these peelers or flowers?
    2) I just picked up a 380mm Brembo GT BBK, will 10mm spacers work with this bbk (is there enough room?)?
    3) I do track my car. Is it ok, or is it a bad idea, to do track days w/ spacers on the car? I just imagine that vibration during high speeds and aggressive turning and breaking would not be idea, but if the spacers are properly installed and the fitment were snug, would they be ok on the the track?
    Ernie
    Mar 21 2015
    Quote Originally Posted by Ernie1060 View Post
    Couple questions...
    1) What is the diff between 19" "peelers" and "flowers". I have the 19" OEM wheels, are these peelers or flowers?Ernie
    http://www.audizine.com/forum/showth...AQ-s-and-DIY-s
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    I wanna order the OE springs, so this is good news as I'm running the 10/12.5mm spacers.
    Aug 01 2015
    Edmonton, Alberta
    Stock:
    HR OE:
    HR OE + ECS 10 and 12.5
    Dec 30 2012
    Mountain View, Ca
    Awesome!!
    Thank you. I have peelers.
    Oct 02 2006
    Wadsworth,OH
    Looks great!!
    Jason
    Dec 30 2012
    Mountain View, Ca
    Looks great!!
    Jason
    Hey Jason,
    Can you help me out here?
    Ernie
    Oct 02 2006
    Wadsworth,OH
    Should have no issue running 10mm spacers and the 380 kit as well as tracking with the spacers. Just be sure the lug bolts a the proper size to accommodate 10mm spacers.
    Jason
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    The Flush Kit for the B9 A4 appears to be out now. I realize the body/chassis might be different, but I found it interesting that the kit contains a 12.5mm spacer out back and a 10mm spacer up front.
    http://www.audizine.com/forum/showth...-Fit-Kit-B9-A4
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Acejam View Post
    Rotor hub offset, chassis, wheel offset all have an effect on how much space a manufacture leaves for wheels to be spaced out. Not surprising if Audi made changes from a previous chassis.
    Jason
    Aug 01 2015
    Edmonton, Alberta
    So I originally posted that there was no issues with my setup.
    Turns out I am getting some rubbing in the rear under hard cornering, only seems to be happening on the rear passenger side.
    This only happens if I have one or more passengers.
    Wondering if anyone else is having this issue, and which spot would I be rubbing on?
    My setup is stock flower wheels with stock tires, HR OE springs + ECS 12.5 mm rear and ECS 10 mm front.
    Aug 01 2015
    Edmonton, Alberta
    Anybody? Not sure why I would be rubbing on this, particularly only in the passenger rear??
    Oct 02 2006
    Wadsworth,OH
    Likely cause your camber has not been adjusted after you lowered your car.
    Jason
    Apr 05 2016
    Dallas, TX
    I got rubbing as well in the passenger rear during bad dips and hard cornering. I've got the flush kit installed on stock 19" peelers and lowered on coils.
    I got an alignment done with the coil and spacer install, even went back to get raised 3/4 inch, but still rubs (not quite as bad).
    Thinking of swapping the 12.5's for 10's or even 8's.
    Mar 21 2015
    ^ Everyone complains about the 8mm, I'd start with the 10 if I were you.
