Results 1 to 16 of 16
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Jerking on Reverse and 1st gear..
    as easy as i am with the pedals when reversing or going forward from a stop, the car jerks and i do a lil head bang. its getting a bit annoying. could this be a tranny issue ? i do have a fwd cvt.
    my warranty expires this month and luckily ive already got a service scheduled next monday.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I think that's illegal in most countries.
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    probably the motor mount?
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    May 20 2010
    Quote Originally Posted by ducati View Post
    What is? Headbanging?
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    It's the CVT.
    The only way to fix a CVT is to get rid of it.
    My current rides...
    Audi
    Jetta
    Jul 08 2015
    Quote Originally Posted by Jacon View Post
    It's the CVT.
    so youre saying its normal?
    i thought all audis were awds when i bought this.. i was wrong.
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by JeriQo View Post
    No, its not normal and only will get worse.
    The CVT is a piece of shit transmission and most don't last past 100K.
    My current rides...
    Audi
    Jetta
    Jul 08 2015
    great..
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    It's the CVT. If you ever ridden a snowmobile, you probably noticed the same thing. Rpms need to come up a bit before it is engaged.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    JeriQo, I'm free this Saturday, let's get the CVT traded in for a new whip. ;-)
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Can you describe the jerking? Is it a really fast jerking followed by a release? A slow jerking that builds up to a fast jerking followed by a release? Is it a jerking without a release that ends in frustration?
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Jul 08 2015
    Quote Originally Posted by zcspec View Post
    cmon bro i just spent 5 hours hand waxing it last sat..
    Jul 08 2015
    Quote Originally Posted by ToddBrunswick View Post
    what a tease...
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    great..
    You can buy time by performing a fluid and filter change, but it's relatively expensive because the filter is inside the transmission housing and the fluid is expensive. However, a fluid change is cheaper than a new $4K tranny or new car.
    I'd change fluid every 40-50K.
    My current rides...
    Audi
    Jetta
    Jul 08 2015
    thanks for the tip! u currentlu still have 14k miles on it
    May 10 2015
    Pittsburgh PA
    Our family has a 2012 with the Multitronic CVT transmission and it does the same thing as well, particularly when it's cold. It definitely isn't normal as it didn't do this when we got the car, but the dealer hasn't been able to replicate the issue so it's gone unsolved. If you find anything out please let me know!
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
