Results 1 to 2 of 2
Thread: Unique problem
    Dec 03 2015
    1973 Volvo P1800es, 1978 Corvette L82, 1988 Porsche 924, 2009 Nissan Titan, 2004 Audi A4 1.8t
    Atlanta
    Unique problem
    I had my ecu out and battery unplugged when I put my new turbo in. Everything is connected and functioning properly except the warning center in the middle of the gauges keeps telling me that; I'm low on fuel(half tank full), my headlights don't work(both function fully), my brake lights don't work(both function fully), my side markers/turn signals don't work(all function fully), my coolant is low(coolant is full with correct VW coolant), my oil pressure is low(no symptoms of such but this causes me not to drive the car). Obviously this is an electrical fault I presume. I have disconnected both battery terminals and had them touching for an hour but the warnings still persist. Do I need to find someone with a VAG com to reset these error messages?
    Aug 26 2005
    Yes, you need to scan the central electric control module for stored fault codes. That is address 09 in VCDS. Otherwise, the CECM may be faulty. Electronic devices can fail for no obvious reason in an arbitrary way sometimes,.
    Vorsprung durch Technik
