Originally Posted by
Shimmy
hmm, you've got an alu kruez and S5 sways... have you done sway endlinks?
I would think you'd see more benefit with that considering your mods vs. getting 3mm thicker sways.
Haven't done anything beyond the sways. Sway bars were one of the first things I did after getting the allroad. Since then I've pretty much forgotten about them.
zcspec
You should ask yourself, what is the end result? Are you tracking? Are you driving back country roads spiritedly every weekend? Or, do you have money just burning holes in your pocket? If you believe the ROI is worth it, then do it. I plan on tracking the AR so upgrading from S5 sways (in your case) to beefier ones would be a no brainer.
I don't track the car. I do like to drive spiritedly frequently, particularly on the way to a day in the mountains skiing or mt. biking. I do have to admit that this is a bit of the "hole in the pocket" syndrome.
As I said above, I really don't have complaints per se on how the allroad handles. I do like to upgrade things and this seems like an upgrade that I would appreciate...
