Page 1 of 4 123 ... LastLast
Results 1 to 40 of 138
    Veteran Member Three Rings breal's Avatar
    Nov 15 2010
    IN
    2005 B6 S4 Part Out
    POST UPDATED 9/27. LOTS OF INTERIOR PIECES AVAILABLE STILL
    I have decided to part out my 2005 B6 S4, Dolphin Gray with black interior and platinum seats. 6 speed, 153k miles. I originally pulled the engine last month to do some head work and check the timing components, but found more scoring in the cylinders than I was comfortable with. Combined with some other known and newly discovered issues, the revival became uneconomical.
    What you see in the pictures is what you will receive.
    If I don't have pictures, just ask and I'll provide some. If you have any questions about what you see, please ask them up front. I can always provide more information and pictures. In some cases I may have hardware not in the pictures that I can include.
    Everything for sale here is sold as is. I am not trying to rip anyone off, but please remember this car is 11 years old and has 153k miles on it. I will provide descriptions and conditions of the parts as best as I can. If for any reason you have concerns about what you have purchased/received, please PM me first so we can discuss personally.
    I will accept PayPal, or cash if picking up or meeting. I will attempt to get all parts shipped out as soon as possible and will let you know if there will be any kind of delay.
    This is a part out in progress, so if you don't see a part listed in either of the two lists below please ask and I will let you know if it is still available and send pictures and condition information. I am also still working on taking pictures of everything I have disassembled.
    The engine is mostly disassembled, however I'm currently thinking about keeping the block, internals and cams.
    Parts that are not for sale or have been sold:
    Main radiator(cracked on passenger side)
    Stock downpipes
    ECS 5mm spacers with black bolts
    Driver's side engine cover
    Passenger side engine cover
    Front engine cover
    Driver's visor and clip
    Passenger clip
    Rear view mirror
    Intake spacers
    034 Rear sway bar
    034 Rear end links
    Side mirror assemblies
    Lower front grille
    JHM short shifter
    Door blades
    JHM Clutch/Flywheel kit
    Front Speakers
    Valve Covers
    034 motor mounts
    Check valve kit
    Adam's front rotors
    Front calipers
    Front EBC pads
    Front ECS SS lines
    Front dust shields
    Raxles rear axles
    034 front end links
    Magnaflow mufflers and Yonaka tips
    DTH carbon fiber side skirts
    Parking brake lines
    Rear Knuckles
    Rear calipers and carrier
    Rear ECS SS lines
    Alternator U pipe
    Front headlight leveling sensor
    Bi-Xenon headlights
    Manifold Diaphragm, sensors
    Power steering reservoir
    Offbrand PCV
    Upper intake manifold
    Water pump and thermostat
    Rear exhaust hangers
    Rear diff service kit
    Fog light housings
    Fog light grills
    HID fog kit
    H&R coilovers
    Driver's door card
    Driver's door rubber molding
    Card Tray
    Front Cup Holder
    Cargo Net
    Passenger Door Lock Button
    Tow Hook Cover
    Cam Solenoids
    H&R 15mm spacers and bolts
    H&R 10mm spacers and bolts
    1 Set of floor mats
    Spare tire cover
    Headlight knob
    Shifter linkage
    Hood strut
    First Aid Kit
    Front Bumper
    Rear Bumper
    SPC adjustable upper control arms
    Driver's front door
    Taillights
    Parking brake button
    Entire Seat Set
    Passenger front fender
    Transmission
    Headlight mounts
    Front Axles
    034 Transmission mount
    Rear rotors and pads
    Sunroof
    Saiko Michi catch can
    Parts that are for sale:
    Exterior
    Rotiform Nue 19x8.5, machined faces, with Michelin PSS 245/35/19 (Also have a spare, bent, Nue with Hankook V12) - wheels have some scratches and two tires have sidewall wear from rubbing on fenders.
    Less than 10k miles on the tires.
    http://i.imgur.com/xlHbExJ.jpg http://i.imgur.com/Gqxl7aJ.jpg http://i.imgur.com/on9bPGX.jpg http://i.imgur.com/MPipvV4.jpg http://i.imgur.com/lWtbdUO.jpg http://i.imgur.com/sicdI4F.jpg http://i.imgur.com/3dphRCe.jpg http://i.imgur.com/0mQKQ9e.jpg http://i.imgur.com/7oPlUQU.jpg
    http://i.imgur.com/IP1KNTe.jpg
    Upper Front Grille, Plasti dipped black - decent condition, multiple tabs broken but still holds fine
    http://i.imgur.com/IwF136Q.jpg http://i.imgur.com/yvTvEGn.jpg
    Front Belly Pan - Good condition, with a crack at front and back. No bolts included
    http://i.imgur.com/DZEsUOg.jpg http://i.imgur.com/YNChhQ7.jpg
    Transmission Belly Pan - Good condition, with some wear towards the back. No bolts included
    http://i.imgur.com/6o3Cszp.jpg http://i.imgur.com/9Kgf284.jpg
    Side Underbody Covers - Includes small front pieces. Good condition with some burn/melting from exhaust cutouts.
    http://i.imgur.com/Pp6Zske.jpg http://i.imgur.com/pixy3KY.jpg
    Exterior Panels - Hood, Doors available. All have some wear with 153k miles on. Ask for more information and pictures.
    Interior
    Center Arm Rest - covered in microsuede, small stain in back of storage compartment
    http://i.imgur.com/OvHXrBY.jpg http://i.imgur.com/cJUu7rr.jpg http://i.imgur.com/qFZjWZy.jpg
    Dimmer Pod
    http://i.imgur.com/cBuKCj2.jpg
    Seat Memory Pod - has some scratches and fading
    http://i.imgur.com/Jb50ukM.jpg
    JHM Delrin Shift Knob with blank top - good condition, has washers and set screws
    http://i.imgur.com/RJAleiT.jpg
    Interior Trim carbon fiber fabric wrapped by PO, currently missing front ashtray in picture - decent condition, fabric is loose along the edges in some places, rear ashtray mechanism is broken, small dash piece has a broken mounting tab
    http://i.imgur.com/xSPNDQrl.jpg http://i.imgur.com/cLDspJXl.jpg
    Front Window Motors
    - good condition
    http://i.imgur.com/4oWMuhZ.jpg
    Passenger Sun Visor - Good condition, comes with clip.
    http://i.imgur.com/ibIxGXel.jpg
    Trunk Release Pod - some scratches and fading
    http://i.imgur.com/K4YwQ7N.jpg
    Navigation DVD Case - Has 10 DVDs
    http://i.imgur.com/JvA6jUI.jpg http://i.imgur.com/cjXg62w.jpg
    Owners Manual Case - See pictures for everything included
    http://i.imgur.com/SOpAGt1.jpg http://i.imgur.com/NULnukE.jpg http://i.imgur.com/KsMJKvL.jpg
    HVAC Control Unit - few scuffs at bottom
    http://i.imgur.com/lRFJwNA.jpg
    Inside Door/Mirror Trim - pieces around side mirror mounts, good condition
    http://i.imgur.com/5ubfJFG.jpg
    Fuse Panel Cover - good condition, comes with tools
    http://i.imgur.com/bSiahGY.jpg http://i.imgur.com/3nVeE6u.jpg
    Trunk Netting Hooks - Good condition
    http://i.imgur.com/iRtp10Hl.jpg
    Trunk Interior Panel - Good Condition
    http://i.imgur.com/V0WPd2Kl.jpg
    Trunk Driver's Panel - Good Condition
    http://i.imgur.com/2keiAnSl.jpg
    Trunk Passenger Panel - Good condition
    http://i.imgur.com/BGmpXcsl.jpg
    Trunk Bottom Kick Panel - Has wear and scratches
    http://i.imgur.com/oVlGd7Jl.jpg http://i.imgur.com/QZHv2SWl.jpg
    Floor Mats - Have one set left. Driver's have some discoloring and the passenger mats has a few stain spots
    http://i.imgur.com/0QwbhDJl.jpg http://i.imgur.com/zlpzON6l.jpg http://i.imgur.com/MLfIVTNl.jpg http://i.imgur.com/v7er28vl.jpg
    Roadside Jack - Good condition
    http://i.imgur.com/H8QfHPNl.jpg http://i.imgur.com/r02nE9hl.jpg
    Pillar/Roof Trim and Headliner - Good condition with few scratches and scuffs. Headliner has a stain on each side in the back.
    http://i.imgur.com/P5UpCzu.jpg http://i.imgur.com/GSGuXq7.jpg http://i.imgur.com/VgCjmw9.jpg
    Overhead Electronics/Handles - Good condition.
    http://i.imgur.com/JCBXw36.jpg
    Engine/Drivetrain/Mechanical
    Rear Engine Cover - good condition
    http://i.imgur.com/FOPSRTs.jpg
    DMH Electronic Cutouts pair, low profile, still installed on downpipes. Comes with block-off plates and hideaway switch mounted in place of cigarette lighter - still functioning but motors need rebuilt. Pictures show when I first bought and installed.
    http://i.imgur.com/Myf7QFg.jpg http://i.imgur.com/i2YTWEG.jpg http://i.imgur.com/vaxRICJ.jpg
    K&N Air Filter - cleaned 5k miles ago
    http://i.imgur.com/fTp7SSA.jpg
    Fuel Line and Injectors new pintle caps and o-rings installed 5k miles ago, also comes with extras - good condition
    MAF Sensor and Housing - 20k miles on, good condition
    http://i.imgur.com/2bdOrme.jpg
    OEM PCV - 2k miles on
    http://i.imgur.com/7dRq8H2.jpg http://i.imgur.com/vEbNQUe.jpg
    Throttle Body - good condition
    http://i.imgur.com/N2yu6dH.jpg http://i.imgur.com/oRT8txD.jpg
    Suction Pump - 5k miles on, good condition.
    http://i.imgur.com/nfDxfWM.jpg
    Rear Wheel Bearing Assemblies - 20k miles on bearings. comes with hubs
    http://i.imgur.com/zg1YTst.jpg
    Intake Piping - good condition
    http://i.imgur.com/wFEJPVm.jpg http://i.imgur.com/gM4I3Zx.jpg
    Windshield Washer Fluid Reservoir - no leaks
    http://i.imgur.com/211RZRz.jpg
    Windshield Cowl - decent condition, see pics for issues. tabs intact
    http://i.imgur.com/r4JM798.jpg http://i.imgur.com/8SmTYWr.jpg http://i.imgur.com/TJr9lfx.jpg http://i.imgur.com/eWGI8Q1.jpg http://i.imgur.com/kxArTP1.jpg
    Apikol Snub Mount can come with stock bracket - 5k miles on, good condition.
    http://i.imgur.com/SPe1uk5.jpg
    Fuel Pump - Replaced 3 years ago, 30k miles on. Picture soon
    Wiper Motor Assembly - working condition
    http://i.imgur.com/bHY8dAH.jpg
    Hood Release Latch and Cable - good condition, replaced 2 years ago
    http://i.imgur.com/2oDXqdU.jpg
    Suspension
    Rear Subframe Spacers stock - new
    http://i.imgur.com/0AD0Y2a.jpg
    Meyle Lower Front Control Arms - 5k miles on, good condition
    http://i.imgur.com/foexvwE.jpg http://i.imgur.com/zRFkhY2.jpg
    Performax Front Sway Bar Bushings - 4k miles on, good condition.
    http://i.imgur.com/Ii6176q.jpg
    Front Uprights
    TGM C7 S6
    DG B6 S4
    2017 Colorado Z71 Duramax
    2006 Triumph Daytona 675
    Jul 30 2014
    My baby b6 s4 good wood green pearl, A bunch of b5 a4s, 86 Toyota pickup
    Bellingham,WA
    Pmd about tuned ecu
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Side engine cover. Front and back engine cover pmd
    Sent from my VS990 using Tapatalk
    Apr 12 2016
    Hollis, NH
    PM'd about Front Speakers and Coilovers
    Nov 15 2010
    IN
    Quote Originally Posted by JDish92 View Post
    Pmd about tuned ecu
    Nothing in my inbox from you
    Quote Originally Posted by [a]bek. View Post
    Replied
    TGM C7 S6
    DG B6 S4
    Nov 15 2010
    IN
    Quote Originally Posted by SilverAudIan View Post
    Replied
    TGM C7 S6
    DG B6 S4
    Apr 18 2015
    Dallas
    Pm'ed you.
    Apr 01 2016
    do you still have the front engine cover, and do you have a tranny pan and how come your not selling the belly pan?
    Dec 07 2009
    East Coast
    Wow sad to hear such news Does parting out really bring in that much money vs selling car as is online?
    Forget the B8, keep the V8!
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Lower grille, intake spacers. Price. Thanks.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    PM'd
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by MurkyRivers_A4 View Post
    PM'd
    didn't get a PM, if that was actually to me...
    Dec 17 2009
    Kentucky
    Quote Originally Posted by Terry.Reese View Post
    No sir, not to you but rather the OP. He has responded.
    I usually quote the initial post but, due to its length, I decided against it.
    Sep 08 2014
    East LA
    ECU, shifter, shift knob.
    2132589600
    Nov 15 2010
    IN
    Quote Originally Posted by wolv1414 View Post
    Pm'ed you.
    Replied
    Quote Originally Posted by G_Vigo View Post
    Engine covers are pending. I actually don't know if I have the belly pan anymore, and if I do, not sure what condition it's in. I wanted to get an aluminum one, but never did. I'll check on the tranny pan tonight.
    Quote Originally Posted by Mr.Wrong View Post
    Yep I'm pretty unhappy. Not considering my labor or time, yes it should.
    Replied
    PM'd
    Yup I may have gone overboard.
    TGM C7 S6
    DG B6 S4
    Dec 17 2009
    Kentucky
    You didnt go overboard. The more detail the better.
    Nov 15 2010
    IN
    Just an update on the ECU, I do not know what is involved to get it transferred to another car. This will be on the buyer, unless I absolutely have to do something.
    TGM C7 S6
    DG B6 S4
    Nov 15 2010
    IN
    Quote Originally Posted by rayray1688 View Post
    2132589600
    All pending atm. I'll update when I hear back.
    TGM C7 S6
    DG B6 S4
    Sep 08 2014
    East LA
    Let me know, I'm really interested
    Apr 01 2016
    Well let me know about the two belly pans, as long as they are not in pieces I'm willing to buy them along with some other goodies that we will talk about after.
    Nov 15 2010
    IN
    No pans at all. I thought I had them up in my parents attic, but I didn't find anything.
    TGM C7 S6
    DG B6 S4
    Apr 07 2015
    Los Angeles CA
    I PM'ed you
    Nov 15 2010
    IN
    PM sent
    Quote Originally Posted by Junglenrg View Post
    I PM'ed you
    I do not have any PMs from you.
    TGM C7 S6
    DG B6 S4
    Sep 08 2014
    East LA
    News?
    Update?
    Nov 15 2010
    IN
    News?
    Update?
    I sent you a PM...
    Tune and shifter still available. See my disclaimer about the tune.
    TGM C7 S6
    DG B6 S4
    Established Member Two Rings WillB6A4's Avatar
    May 31 2014
    New York
    Seats forsale?
    B6 A4 daily KO4
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    PM Sent
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Nov 15 2010
    IN
    Quote Originally Posted by jmcS4 View Post
    PM Sent
    Replied
    Quote Originally Posted by WillB6A4 View Post
    Seats forsale?
    Yes they are. I've got them disconnected, just need to remove from the car. Platinum seats, driver's seat has wear and discoloration on the bottom bolstering, passenger seat is in good condition. All mechanics work. You need the back seat too? I'll take pictures this afternoon.
    TGM C7 S6
    DG B6 S4
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by breal View Post
    Replied
    Pm'd you as well.
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    Foglamps and fog grilles to 02169? How pitted are the lenses?
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Nov 15 2010
    IN
    Quote Originally Posted by ZipMeUpJ View Post
    Are you wanting all the HID stuff? I'll take some better pictures of the lenses and some of the grilles. The plastic bolt on one of the grilles, maybe drivers, is broke, so it was held on by a screw into the bumper.
    - - - Updated - - -
    I'll hopefully get around to updating this thread tonight. Busy weekend elsewhere.
    TGM C7 S6
    DG B6 S4
    Nov 12 2012
    hologram R8
    boston
    No HID stuff thanks! let me know
    Nov 15 2010
    IN
    PM sent
    TGM C7 S6
    DG B6 S4
    bump, great seller with quick shipping and replies! thanks again !
    B7 S4 Dolphin Grey - Current.
    8P A3 2.0T 6SPD Full Stage 2 Arctic White - SOLD
    Veteran Member Four Rings ABT B7's Avatar
    Jan 27 2007
    MB C350 4M
    Alberta
    Intake manifold?
    Mods: 15% Tint 19" Avant Garde M621 Antique Matte Bronze LED License Plate Lights + City Lights+ Interior Neuspeed Catback Oettinger Roof Spoiler Painted Reflectors + Rear Valance 5000K HID Fog 6700K D1S JHM SS TTRS Steering Wheel Apikol rear diff mount JHM Intake Spacers JOM LED Tail Lights AWE Down Pipe PSS 235/35/19, JHM LW Rotors Akebono Euro Pads StopTech SS Lines JHM Tuned Full Oettinger Kit KW V3
    Future: JHM Pulley+ IM+ Stg1 S/C
    Nov 16 2013
    Lower NH
    bump for a good seller!, care was taken when my items were shipped!! thanks again
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Jul 04 2015
    Ajax, Ontario
    Do you have the coil overs still??
    Junior Member Two Rings
    Jan 06 2007
    WA
    Sent you a PM. Thanks
    Nov 15 2010
    IN
    Thanks for the feedback guys.
    Quote Originally Posted by ABT B7 View Post
    Intake manifold?
    PM sent
    Quote Originally Posted by Manutdfan1 View Post
    Yes, PM sent
    Quote Originally Posted by 95ninety View Post
    Replied.
    TGM C7 S6
    DG B6 S4
    Apr 22 2016
    B6 S4 Avant, Milltek exhaust
    Teller
    PM Sent re: Front rotors
