Results 1 to 12 of 12
    Active Member Three Rings auditrackspeed's Avatar
    Jun 17 2014
    Is it bad to use stock intercoolers with K04's
    Front mount just got me in trouble with the cops , i have some side mounts laying around can i use them until i get upgraded side mounts . ( i dont wanna carve up my front bumper for the fmic )
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Sounds like your lack of a front bumper got you in trouble with the cops, not the intercooler itself, no?
    Jun 17 2014
    Quote Originally Posted by mauromj View Post
    Good one troll . Get to bed
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    It's only "bad" in the sense that your car will not perform to it's potential in many conditions.
    It isn't harmful.
    Quote Originally Posted by auditrackspeed View Post
    He's right, you know...
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 17 2014
    Quote Originally Posted by LINDW4LL View Post
    Your car will simply not perform to it's potential in many conditions.
    Correct but its pretty clear it was my fault , didnt need to be a smart ass about it ...
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    What kind of boost? Pushing high boost through stock intercoolers can have some serious negative effects on the poor turbos
    Jul 23 2012
    Pullman, WA
    Since I am a "troll" now according to you, I must ask a question; have you used Google before?
    In 4.6 seconds I found the following thread: http://www.audizine.com/forum/showth...k-Intercoolers
    I also found this (1st result): http://www.myaudis4.com/stock-intercoolers/
    So with that being said, yes it is "bad" to use the stock intercoolers on k04's.
    Jul 04 2012
    Woodbridge, VA
    Bad? No. Reliable? No. My stage 3 k04 ran stock inter coolers at 24psi until the day I changed them last week (from 2010).
    I'm sure they were on borrowed time.
    Jul 24 2014
    A giant mess.
    AK
    ^true.
    The PO of my car went with the APR stage 3 kit in 2010 and left the stock intercoolers. I just got the SRM SMIC's last month, the only time I had any negative effects with the stockers was in stop-and-go traffic one day last summer. I also live in Seattle though, and it doesn't get rediculously hot here.
    A link was posted to Flyboys "MyAudiS4" site, I'd recommend reading through and it should give you more than enough info on the pitfalls of running stock IC's vs. virtually every other available IC.
    .Edited for grammar.
    Jun 17 2014
    My bad i was just a little upset , but thanks for the input bro
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    With higher psi, the plastic end tanks on the stock intercoolers can fail/separate from the aluminum body.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    This thread makes me giggle.
