Results 1 to 8 of 8
    Senior Member Three Rings Speedybrit's Avatar
    Apr 15 2010
    USP Motorsport Interior LED Issue
    I installed the USP interior LED bulb kit (http://www.uspmotorsports.com/Audi--...r-LED-Kit.html) about 2 months ago and the past week or so the lights have been flickering as if there isn't enough power going to them. Has anyone else had a problem with this? Any solutions? It does it whether I am getting into a cold car or after driving for 20-30 mins so I don't think that's a problem.
    Current Cars:
    2016 Sepang Blue S3 - Tech Pkg, Black Optics, B&O - Eurodyne Stage 2 ECU/TCU (Crackle Tune), Resonator Delete, CTS Intake, CTS Turbo Muffler Delete, CTS Turbo Inlet, USP Downpipe, APR Roll-Control Springs, APR Rear Sway Bar, and PowerStop Z23 Brake Kit
    Past Cars:
    2013 Monsoon Gray B8.5 A4 Prem+ 6MT
    2010 Meteor Gray B8 A4 premium 6MT
    2008 Subaru Legacy
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I have the same kit and I have not had that issues. Is it all of the bulbs or is it just one? If it is just one then LED is probably going bad. If it is all of them, then it might be an electrical problem.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Apr 15 2010
    Quote Originally Posted by Baggio View Post
    It's usually the center front dome and one of the rear. It's not all of them at the same time. Is USP on the forums or should I email them direct?
    Current Cars:
    Past Cars:
    2008 Subaru Legacy
    Registered User Four Rings Phil@USP's Avatar
    Sep 18 2012
    Coral Springs, FL
    If it is a problem with a bulb please let us know and we will be happy to send a replacement for this. You can email: [email protected]
    Please include your order number and a brief description of the issue to help identify the problem.
    The kits have a lifetime warranty through us :)
    Phil
    Aug 28 2013
    Quote Originally Posted by Speedybrit View Post
    Sounds like those 2 bulbs are going bad.
    Dec 11 2015
    Syracuse,NY
    I have the same problem :( the front one and one of the rear
    Feb 01 2016
    Marietta, GA
    Quote Originally Posted by ximo03 View Post
    I have done a lot of interior LEDs in different cars. Typically I source the sizes all separate. I have found that some bases or configurations aren't optimal for the ballast/base that it us going into.
    Check the fitment to see if you have a good connection. The overheads are the only ones in the configuration on the interior, so it may be the bulb connection itself.
    Sep 18 2012
    Coral Springs, FL
    Just send us an email and we can take care of this for you. :)
    [email protected]
    Phil
