Results 1 to 7 of 7
    Veteran Member Four Rings A6C5V842's Avatar
    May 11 2010
    PNW
    Self leveling headlights?
    Hwy guys,
    Quick question.
    Changed my headlight bulbs the other day and now I'm convinced the auto level thing isn't working!
    Any thoughts?
    Cheers,
    Glyn - with a "y"!
    Nemo - Manual!
    Email me
    Theory can get you killed. Skill and observation are your only way out
    May 11 2010
    PNW
    FYI... I figured it out.
    All good now...
    Mods you can delete this one if you like.
    Cheers.
    Glyn - with a "y"!
    Nemo - Manual!
    Email me
    Veteran Member Three Rings vlangs's Avatar
    Nov 09 2013
    Manhattan
    lol...mods...yeah we have those :p
    but what was the problem?
    Senior Member Two Rings BlackOnBlackA6's Avatar
    May 24 2005
    '01 A6 Avant 2.8
    Fairfax, VA
    Yes. Incase one of us (me) does the same thing. It will be most helpful to know. -thanks
    May 11 2010
    PNW
    Honestly guys I don't know what the problem was. I took the light apart to check all the connections, put it back together and re tested. It worked. I think something must have either been loose or maybe not put back together quite right. I will have to manually adjust them now though as the beam from the new bulbs is massive compared to the old and the passenger side is higher. Always something . . . .
    Glyn - with a "y"!
    Nemo - Manual!
    Email me
    May 24 2005
    '01 A6 Avant 2.8
    Fairfax, VA
    Passenger side is suppose to be higher for safety and legal reasons. Driver's beam is a bit lower to keep from blinding oncoming traffic. Figured this out when looking to purchase lights overseas that gave option for cars that drive on either left or right side of the road. Do a little research so you don't make the passenger side too low.
    Just a heads up incase that is what you're experiencing. If not, forget everything I wrote
    Cheers
    May 16 2008
    South Texas
    The rods going from the control arm to the sensor are a common failure point. Water gets in the ball joints and bad things happen.
