Results 1 to 18 of 18
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Front subframe/engine cradle interchangeable ?
    Does anyone know if our front subframes are interchangeable with an A5?
    I know it's interchangeable with a4s but found an a5 for 300.
    Recently hit a pothole at 5mph, clipped the road and cracked the subframe so need to get this fixed asap.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Aug 03 2014
    Queens
    Anybody?
    Previous
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Is the part number the same ? (probably stamped into the subframe somewhere....) or check EKTA parts catalog for S4 versus A5.
    Aug 03 2014
    Queens
    It seems like all the part numbers are the same, whether DSG or manual.
    ECS does say that it's good for RS5 but it's manual? Don't recall rs5 in manual but I'm sure the fitment trickles down to the sub platforms of the rs5.
    I'm taking it to a frame shop tomorrow to make sure no structural damage to the unibody (at 5 mph I can't see how) but it was a pretty good lick and it is a 4000lb car.
    If I can avoid an insurance claim I'll just drop the subframe myself with a friend.
    If there is unibody damage then I have no choice.
    Previous
    Aug 03 2014
    Queens
    I'll update this thread for reference just in case anyone cracks their subframe.
    Seems like all B8 subframes are interchangeable 4-8 cylinders a5 family and a4 family , manual or dsg.
    These holes include different mounting points for different engine mounts on all b8 motors.
    Hopefully you don't end up one day in this situation but also hopes this helps if you do.
    Previous
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    Any updates? I just did something very similar & am looking for any details you can provide.
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Aug 03 2014
    Queens
    What is it exactly you need?
    Previous
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Quote Originally Posted by DGVR6 View Post
    It's been this way since the B5 platform. The subframe has the various mount points for the different engine configurations for the given platform
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by kcobourn View Post
    My 2011 B8 S4 subframe was bent (would not pass alignment after front left collision was repaired), and I was lucky enough to find one on a "limited quantity sale" (they had one left) at ECS Tuning, for $619 (it's now $1501). The ECS website page shows which models the part number 8T0399315G fits.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jan 04 2013
    2008 Acura MDX
    United States
    How much labor did you get charged to swap the subframe out?
    Aug 03 2014
    Queens
    Shops were giving me quotes of $400. I just did it with a friend.
    Honestly, I wouldn't trust too many shops to do a job like that. Find a reputable shop.
    Sorry to hear about your subframe
    Previous
    Jan 04 2013
    2008 Acura MDX
    United States
    Yea very true. Did you just strap the motor for support or did you use a legit engine support?
    The only DIY I've seen are on the B7, Saturn, and Jeep forums
    Aug 03 2014
    Queens
    Fortunate enough to use a engine cradle, you can probably improvise.
    It's a sucky job if you're doing it by yourself, easiest part is removing, lining all the bolts up are a bitch.
    I used 034's motor mount for the b8 s4 as a reference
    Ill try to break it down as far as I can remember.
    Set the cradle, jack up the car on all 4.
    Remove the front wheels, loosen sway bar link bolts and tie rod bolts.
    Remove chassis brace, don't lose washers.
    Loosen steering wheel collar from rack, loosen fluid lines from rack and unplug the connector.
    Two bolts hold the steering rack in place, remove those and don't lose the washer.
    Start loosening the engine mounts to subframe
    From there I used a jack to hold the subframe and removed bolts evenly on both sides.
    Like I said to get everything back is the worst part, even with help. I just threaded everything by hand, used an impact driver and tried to get everything evenly tight by feel.
    Previous
    Aug 03 2014
    Queens
    As for special tools you'll need a few triple squares. Everything else you should have.
    Previous
    Jul 18 2010
    NE Ohio
    When my subframe was replaced a couple of months ago at the Audi dealer, the charge on the insurance documentation to remove and replace the subframe was $924.60. I believe that included replacing any single use stretch bolts, properly torquing all bolts to proper specs, etc. I believe they used special tools to support the engine/trans while the subframe gets switched out. This was all covered by the insurance company of the 22 Y/O girl who hit our car. Add another hundred something for the alignment on top of that. Glad it didn't come out of my pocket.
    Jan 04 2013
    2008 Acura MDX
    United States
    My regular shop (Brink Motorsports) is doing the work @ 5 hours for the engine cradle swap. Not bad. Insurance is covering & it's a 'no fault' claim - woOt!
    While in there going to swap to 034 mounts. Just got new OEM ones if anyone's interested :-)
    Aug 03 2014
    Queens
    Nice, glad it everything came out good!
    Previous
    Jan 04 2013
    2008 Acura MDX
    United States
    Thanks and appreciate the how to - hopefully someone can use this in the future.
