Results 1 to 6 of 6
    Established Member Two Rings SacSantorin's Avatar
    Aug 18 2015
    Almost Canada, WA
    Help! F21 boost problem!
    Hi everyone! So I'm hoping someone has experienced this problem before. I was driving to work today and after gunning through a yellow light the car was struggling to build boost past 10psi. Under WOT in 3 gear it got up to 14-15 psi, but far from the 20psu it normally sits at. I pulled codes with vagcom and got nothing. I'm also noticing what sounds like turbo flutter, which doesn't make sense since I have a diverter valve recirculating the compressed air. Anyone experience anything like this? I'm moving out of state on Saturday and do not have time to tear the car apart looking for this problem. Any tips are greatly appreciated! Many Thanks!
    2000 Audi A4 1.8T | Santorin Blue | Frankenturbo F21L Mixed Flow | Motoza 550cc Tune | Custom 2.5'' Exhaust w/ Milltek Downpipe | 3'' MAF Housing | 3" Ebay Testpipe | CX Racing FMIC | B6 5 Spoke Wheels | ECS Boost Guage | OEM RS4 Grill
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Maybe a boost leak before the DV or a stuck DV. Is it a stock DV? Or when was the last time u cleaned it if it's an after market like a 007. They need cleaning and grease every 5 to 10 k.
    Sent from my SM-T560NU using Tapatalk
    SOLD the GOINHAM A4 ---> GT2860 Project
    Dec 05 2007
    Wastegate, diverter valve, or boost leak.
    Jun 30 2008
    Erie, Pennsylvania
    And I'd add that you want to take it easy until you fix it. If you have a boost leak, it will be spinning its guts out to make 15psi. The turbine RPM (shaft speed) is going to be way past safe.
    Aug 18 2015
    Almost Canada, WA
    Thanks everyone! Found it this morning, vacuum line from the DV had broken into 2 pieces. Replaced and it's running great again. I appreciate the quick responses! I was wiggin out with my move being so close. Thanks everyone!
    Nov 17 2011
    Fredneck Maryland
    Glad we could help !
