Results 1 to 15 of 15
    Jan 08 2010
    '02 S6 avant 01E, '04 A4 1.8tq USP, '06 Scion xA
    SEA, BOS
    Question Diagnosing bad cat?
    2004 A4 1.8tq tip, AMB
    170k miles
    Fuel mileage is poor--in-town driving averages 17-19 mpg.
    Trying to confirm the P0420 (low cat efficiency) code I have is truly a bad cat and not the result of another ailment...
    Are there particular measurements I can log in VCDS to confirm?
    I don't want to just replace parts chasing codes. And if I'm replacing the cat, I'm leaning toward the 034 HFC. The existing cat is not original (Bosal, date code is 0611--not sure if that's 2006 or 2011)
    Related: if I go with the 034 HFC, is the O2 sensor spacer required? I live in an emission-test area.
    History:
    When I got the car (heavily molested in the past by POs), I had P0420 along with SAI related codes and intermittent misfires on cylinders 3 & 4 (interestingly, I never had any Evap codes which bedevils me on my C5 S6!).
    Since buying the car last summer:
    - new plugs
    - new injector o-rings
    - new PCV hoses (034)
    - replaced vacuum check valves, confirmed SJP and vacuum hoses are intact
    - replaced Carbonio CAI with stock airbox
    - timing belt, water pump, coolant flange, j-plug, etc replaced
    Now, only the cat efficiency code remains.
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Couple ways to confirm a failing cat.
    Infrared thermometer temp, pre-cat should be lower than post cat temp.
    More accurate way here... Check post cat O2 voltages, should be very stable and not fluctuate at all if the cat is good, as the mixture has passed through the catalyst neutralizing the AF ratio as opposed to pre cat voltage which will fluctuate regularly.
    Nov 10 2015
    Sudbury, ON
    I have a good stock Cat, a fairly new 3" HFC & a 3" Catless downpipe if your in need of one!
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Aug 26 2005
    The OBDII cat efficiency monitor implemented in the ECU firmware is specifically designed to evaluate the conversion efficiency of the cat converter. The monitor evaluating the cat efficiency can only proceed with the test after confirming correct function and accurate information from the O2 sensors and anything else that could effect the monitor accuracy. Everything is checked and confirmed correct before the monitor is allowed to run. Consequently, the DTC describing the "low cat efficiency" would not be set if something else was actually causing conditions duplicating a tired cat converter. If that was the case then the off spec operating parameters of the other dependant hardware would set other fault codes instead. This is a fundamental technical requirement for OBDII emissions monitors, established by Federal and California emissions regulations.
    Vorsprung durch Technik
    Oct 02 2006
    Wadsworth,OH
    Awesome info here. So cliff notes: If you have a low cat efficiency code you have a bad converter.
    Jason
    Aug 27 2013
    Philly
    Jason
    I feel its tough to say the cat is "bad" if you get a 420 code. With our cars being ULEV, it just means the cats aren't up to par with the ULEV standards, not necessarily completely bad. A cat on our cars throwing a 420, may still be cleaner than a none ULEV car with a brand new cat. Just something to think about.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by SJorge3442 View Post
    True. But does that mean it will or will not pass emissions? Technically if it wont pass emissions you'll have to replace it anyways I would imagine. I think that would be the biggest concern.
    Jason
    Aug 27 2013
    Philly
    Jason
    Depends on the state and their inspection rules I guess. I'm not one to beat the system when it comes to this stuff, but I hear a o2 sensor spacer will keep the 420 code away and pending a smog test with a somewhat decent cat, you should still pass . I don't drive more than 5k miles a year anymore so I don't have to worry about emissions testing in PA.
    Oct 02 2006
    Wadsworth,OH
    Anyone know if you can still pass a smog test with a spacer and a test pipe? Haha.
    Jason
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Jason
    Lots of info in this thread: Clicky click®
    Apr 15 2014
    Ottawa/Gatineau Canada
    Quote Originally Posted by jesse500 View Post
    What kind of HFC? 034?
    I may need one ;)
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Jan 08 2010
    SEA, BOS
    Thank you diagnosticator and old guy--just the people I was hoping would respond!
    Logged B1S1 and B1S2...and as described in old guy's link, I have a fairly dynamic B1S2 :(
    My work replacing vacuum check valves and PCV lines must have dislodged a few other items...I have introduced an EVAP code and I now have an N75 problem (0.00% WG frequency logged)...both of these may be related to the use of a pre-'03 silicone TIP (from APR) which has some convoluted routing of extra hoses...need to find an '04 TIP with all the right hose connections.
    The good is I have until August to get this sorted and pass emissions! The bad is it's gonna be effing hot in my garage in a month.
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    Quote Originally Posted by linust View Post
    I may have a late APR TIP that I'd trade for an early, if you're interested. I'll have to double check that extra one I have is a late.
    Jan 08 2010
    SEA, BOS
    Quote Originally Posted by 16vCorey View Post
    Yes, interested! LMK...as I said, this car was heavily molested by a previous owner, and mostly (but often incorrectly) restored to stock. Thanks
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by Luxus Panzer View Post
    I may need one ;)
    Local Canadian Made. Emico
