Results 1 to 7 of 7
    Dec 16 2014
    Sediment In Coolant Recovery Reservoir
    I had a crack in my coolant reservoir so I replaced it last night. I noticed there was some sentiment in the bottom of the reservoir. My question is, will a flush do the trick or is there anything else I can do to keep my coolant system from corroding?
    Established Member Two Rings Jborch8's Avatar
    Apr 30 2012
    Oil stains
    Issaquah, WA
    Quote Originally Posted by JKCutler3 View Post
    Depends on how attached you are to it.
    2005 A4 B6 1.8t Avant - Moro Blue
    Stage 1 APR Tuning / Eibach Pro Springs with Bilstein shocks
    Aug 26 2005
    The important cooling system maintenance factors are using 50/50 mix ratio of distilled water and anti freeze in the coolant mix, for adequate corrosion inhibition, and changing the coolant every two years. The anti corrosion additives in the anti freeze get used up after awhile.
    Vorsprung durch Technik
    Dec 16 2014
    Quote Originally Posted by Jborch8 View Post
    LoL
    Aug 27 2013
    Philly
    Its likely rubber bits from deteriorating coolant lines. I have it too
    Dec 16 2014
    Quote Originally Posted by SJorge3442 View Post
    So you're saying even if I flush they'll come back until I replace all the hoses?
    Aug 27 2013
    Philly
    Yeah, that's if its the rubber from the hoses. Usually you don't notice this on other cars since the tanks are opaque and coolant is darker.
    Sent from my Nexus 6 using Tapatalk
